Old 03-03-2015, 02:19 AM #1
MandAtaco's Avatar
MandAtaco MandAtaco is offline
MandAtaco is on a distinguished road
MandAtaco's Avatar
MandAtaco (Manda4Runner-?) Build Thread
I never had a full on build thread on my truck and always regretted it. Hopefully I can keep up on it with the Runner so I'll have a reference for everything, and be able to help someone else down the road.
07-27-17 NOTE: So photobucket sucks the big one and changed their hosting, I'm not paying a fortune to host pictures so I'm in the process of switching everything over the FLICKER. For now you can click on the missing picture and at least open it up in photobuckets page. I'll hopefully have everything migrated over in the next 10 years.
Current Pics:
Suspension Mods:
-Donahoe (Icon) extended travel front coilovers
-Camburg upper control arms
-OME 861 Rear Springs
-Toytec Panhard drop bracket, Reinforced to the frame
-Custom rear sway bar links, longer built from Energy Suspension links
-OEM Toyota LC80 rear shocks, frame drilled out to fit the larger centering washer
-.5" PhatPats Body Lift
Drive Train Mods:
-Yukon 4.56 gears
-ARB Front Locker
-Toytec Diff Drop
Current Body/Bumper/Armor
-ARB front bumper
-8" HID KC Lights
-9000# Smittybuilt winch
-Custom rear bumper with Swing out
-Custom low profile rack 3/4" round tube
-CBI ditch light brackets with LED flood lights
Engine/Trans Mods:
-Hilux Snorkel
-Airaid intake tube
-Walker catalytic converter
-Magnaflow 18" muffler with custom rear dump
-Tru-Cool 4589 Trans Cooler (radiator bypassed)
Current Interior Mods:
-Scanguage II with X-guage to monitor trans temps
-LED dome lighting
-JVC Stereo
-WeatherTech Front Floor Mat's in Black
-CalTrend front seat covers
-Bunch of OTRATTW rocker switches
Wheel's/Tires/Brakes
-Braided Brake lines from Wheelers Off-road front and rear
-Tundra 231 Brake upgrade with Duralast stuff
-BFGoodrich A/T KO2's in 285/75R16 on stock Limited 5 spoke rims
-Spidertrax 1.25" wheel spacers
-Matching spare
Camping/Expo/Comfortable Living
-Xantra 1000W inverter (Built into rear storage box)
-Puma Compressor (Built into rear storage box) with 1/2 gallon tank underneath
-6.5' Smittybuilt awning
-Custom rear storage box with table
-IndelB 51 Fridge
-CVT Mt. Shasta RTT
Back story:
My wife and I bought a 01 Tacoma back in 05 and I proceed to build it up over the course of the 9+ years we owned it, eventually ending up with a truck that I felt could do a little bit of everything. We ran the Rubicon, Moab, Big Bear, and a bunch of other places in it, all while daily driving it. It was a bad little truck!
The ONLY problem with this truck, was the lack of seating for my now kids. I tried to get 2 cars seats in the taco, but it was neither going to be comfortable, or safe IMO, so the search was on for a 3rd Gen 4Runner. I started looking for something specific, a 99-00 with 3.4L and a rear locker. I knew if I could find this combination i could save myself a chunk of change by swapping a lot of the parts from my truck onto the Runner. Besides that I knew there was no way I would get my money out of those parts when I sold the truck. I found what I wanted up in Southern Utah. Took the trailer up and brought it home.
2000 Limited, 3.4L, Automatic, Rear locker, 191K miles, power everything, 5 spoke limited Rims, basically everything I wanted!
Frame was mostly rust free (just some surface stuff here and there), everything was just dirty. The previous owner had it for 5 years and by his own account, just drove the thing and had the oil changed.
OverlandNV
-2000 4Runner Build Thread
-2004 4Runner
MandAtaco is offline   Reply With QuoteReply With Quote
Old 03-03-2015, 02:30 AM #2
MandAtaco's Avatar
MandAtaco's Avatar
I got it home pulled it in the garage and started working on it, I literally only did a mile long test drive before I tore it apart! There was some stuff I needed to swap before I sold the truck, and I wanted to get the major tune up stuff done too while I had another truck to drive. First up was to swap the rear third and front diff. I had 4.56 gears and a front ARB locker in the Taco. They got pulled and swapped for the 4.30 gears that came in the Runner.
The rear was a direct swap, the front I had to swap the actuator's out as the taco was electronic controlled, and the Runner is Vacuum controlled.
I also went ahead and installed some new axle seals in the back (they weren't leaking) and installed a set of ADD shafts I had rebuilt a while back as trail spares. They were Green label shafts from a Taco. I had them and knew that the ones on the Runner would probably just start leaking the minute the lift went on anyway.
Some of the other stuff I kept, to give you an idea of where this build is going:
-8" HID KC lights
-Hot water shower heat exchanger
-2 Meter Radio
-Donahoe (Icon) front Coilovers
-Camburg upper Control Arms
-Puma Compressor for locker control and OBA
-and of course this guy..... It'll get fully gone through and installed sometime down the road. Marlin 4.7 "Taco Box".
OverlandNV
-2004 4Runner
Old 03-03-2015, 04:47 AM #3
A.Wilson013's Avatar
A.Wilson013 A.Wilson013 is offline
Real Name: Alex
A.Wilson013 will become famous soon enough
Real Name: Alex
Sounds like you're headed in the right direction!
I am curious if you have more info on this shower thing...? That'd sure be nice to have on long trips.
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
A.Wilson013 is offline   Reply With QuoteReply With Quote
Old 03-04-2015, 12:19 AM #4
MandAtaco's Avatar
MandAtaco's Avatar
Thanks, The shower I have was from R&M Vehicle Mounted Showers... LINK Unfortunately, they quite producing them a few years ago, I had tried to buy another heat exchanger for my wife's rig. Its a great working set up after a long day or days on the trail.
Sorry I don't have better pics, but here it is in my taco.
OverlandNV
-2004 4Runner
Old 03-04-2015, 12:39 AM #5
MandAtaco's Avatar
MandAtaco's Avatar
Once I got all the diffs swapped over, I started working on the tune up stuff. The P/O said he'd never done the timing belt, he had bought it at 130K miles, and had no idea what had been done before that. One way or another I figured it was due. When I pulled the timing belt cover off, this is what it looked like....
Pretty sure it was probably never done. I've done a few of these at around 90k to 100k and none of them looked like that!
Just some other pics showing the age and use of the parts out of the motor. It wouldn't surprise me if most of this stuff was original.
Valve cover gaskets were leaking, they were pretty dried out and would pretty much stand up on their own!
Motor was clean inside though, very good sign that at least the oil changes were done regularly.
I don't have any pics but I cleaned up the engine bay as I went, looks a lot cleaner under the hood now. I also added my Airaid intake tube that I took off my Tacoma, and replaced some of the vacuum lines that were cracked.
OverlandNV
-2004 4Runner
Old 03-04-2015, 07:24 AM #6
nc-grayson's Avatar
nc-grayson nc-grayson is offline
nc-grayson is on a distinguished road
nc-grayson's Avatar
Good looking truck and I'm really excited to see its progress!
nc-grayson is offline   Reply With QuoteReply With Quote
Old 03-06-2015, 12:21 AM #7
MandAtaco's Avatar
MandAtaco's Avatar
Got a couple things done last weekend while I was waiting for the last of my suspension to come in. First was CBI ditch light brackets (super nice product) and some LED Flood lights I picked up from a local friend. I also painted the cowl with some trim paint while I had it off, it was pretty faded out.
I also finished up a roof rack I was working on. Its a low profile, full length deal built from 3/4" .065 tube. I painted it orange thinking it will offset some of the black on this truck (more black is coming), but honestly I don't think I like it. I'll probably pull it this weekend if I get time and paint it black too. Opinions welcome!
OverlandNV
-2004 4Runner
Old 03-06-2015, 12:22 AM #8
MandAtaco's Avatar
MandAtaco's Avatar
I finally got all my suspension parts, rebuilt, cleaned and/or shipped in! So the Suspension goes on starting tomorrow. I've got an appointment Monday for an alignment and tires.
-Extended travel Donahoe's (Icon)
-Camburg arms with new uni-balls and bushings
-New OEM lower ball joints
-New style rack guide
-New steering shaft bellows
-Energy suspension poly rack bushings
-OME 891 rear springs
-Bilstein rear shocks
-Toytec drop bracket that I have plans to reinforce (trying to keep drive shaft/fuel tank issues to a minimum)
-I'm also planning on building an adjustable pan hard bar
Weekend should be fun!
OverlandNV
-2004 4Runner
Old 03-06-2015, 12:30 AM #9
shootmymime's Avatar
shootmymime shootmymime is offline
shootmymime will become famous soon enough
where are you at in vegas? i make quite a few tips down there because my wifes family is there.
they are around owens and lamb.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
shootmymime is offline   Reply With QuoteReply With Quote
Old 03-06-2015, 01:03 AM #10
MandAtaco's Avatar
MandAtaco's Avatar
Good to know! I may be ordering a B/L from ya sometime soon!
I'm down South, Buffalo between 215 and Blue Diamond. My folks live up N, Craig and Allen area.
OverlandNV
-2004 4Runner
Old 03-06-2015, 01:05 AM #11
sweet! if we line things up i might be able to hand deliver and help install it on a customer!! that would be sick!
Old 03-06-2015, 01:07 AM #12
ajonesnv's Avatar
ajonesnv ajonesnv is offline
ajonesnv is on a distinguished road
ajonesnv's Avatar
Good to hear. Glad to see you two possibly hooking up...if it happens, Ill most likely pull the trigger on a 1" lift as well.
I could just drag @MandAtaco up to IF with me one day too
1999 4Runner SR5, with some stuff...
OverlandNV
You can also follow us:
Facebook OverlandNV
Twitter OverlandNV
ajonesnv is offline   Reply With QuoteReply With Quote
Old 03-06-2015, 01:18 AM #13
come on up. pick up a CBI bumper and we can install them and body lifts here. (make sure its in the summer time. i dont want you warm blooded kids to freeze)
Old 03-06-2015, 01:33 AM #14
MandAtaco's Avatar
MandAtaco's Avatar
Overland trip next year?
Cause freeze I will! My blood has thinned out over the last 20 years here!
OverlandNV
-2004 4Runner
Old 03-06-2015, 01:36 AM #15
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
do you want to sell your front front 4:30 diff?????????????????
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
wyanrard's 2003 SR5 V6 build thread/picture thread wyanrard 4th Gen T4Rs 56 02-04-2017 01:03 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
