Old 06-16-2015, 04:25 PM #1
ShooterMcGavin's Avatar
ShooterMcGavin ShooterMcGavin is offline
ShooterMcGavin is on a distinguished road
Arrow Shooter's Build Thread
Here is the build-up of my 1997 4Runner.
I purchased it in January 2014 with about 263,000 miles, looking like this:
And here it is in its latest condition (June 21, 2015):
The Details:
1997 SR5, 3.4 5VZ-FE, 5-speed with Rear Diff Locker (broken and I'm really bummed!), leather, etc.
What I have done (modifications, not maintenance):
-removed running boards and chrome fender strips
-installed Lotus rear trailing arm skid guards
-extended the rear diff breather into the upper rear body pillar
-20% tint on the front windows
-front suspension: Toytec BOSS coilovers with 600 lb springs, 1" diff drop
-adapted the factory blinkers into the cutouts in the front bumper
-rear suspension: LC 8-wrap springs, LC Tokico Black shocks
-installed longer bump stops from late 90's GMC Jimmy
-stretched CV boots
-installed front TJM-17 plate bumper
-installed rear Savage bumper
-installed thinned washer into the throttle body linkage to eliminate high idle
-modified the gas tank skid plate to avoid drive shaft contact during flex
-replaced the shifter seat with one from Marlin Crawler
-removed the cone bump stops from the rear suspension
As of June 29, 2016:
-changed front diff, rear diff, and t-case fluid (all synthetic)
-changed transmission fluid (synthetic)
-changed fuel filter
-bled clutch
-replaced LBJs (OEM, nothing else)
-replaced ITREs and OTREs (OEM, because I'm lifted)
-replaced steering rack boots (poly)
-cleaned MAF and throttle body
-replaced spark plug wires
-replaced spark plugs
-replaced the valve cover gaskets
-cleaned the intake plenum, intake manifold, and intake ports, replacing gaskets
-cleaned IAC and throttle body
-replaced PCV and PCV grommet
-installed a secondary power source in the dash; routed power wire and audio input wire for cell phone into the dash
-timing belt, water pump, tensioner, all rollers, cam shaft seals, crank shaft seal, oil cooler hoses
-replaced the accessory belts
-flushed the cooling system 5 times and filled with 50/50 coolant mix
-installed front and rear anti-roll bars, the front using grease-able poly bushings, both using quick disconnect endlinks
-replaced a kinked hard-line for power steering, filled and bled power steering
-lots more
To be continued...
ShooterMcGavin is offline   Reply With QuoteReply With Quote
Old 06-22-2015, 05:13 PM #2
Here is a screenshot of a video, taken during a river crossing on Memorial Day weekend. Got a little water up over the hood
Old 06-22-2015, 06:01 PM #3
A.Wilson013's Avatar
A.Wilson013 A.Wilson013 is offline
Real Name: Alex
A.Wilson013 will become famous soon enough
Real Name: Alex
Where is this...?
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
A.Wilson013 is offline   Reply With QuoteReply With Quote
Old 06-22-2015, 06:20 PM #4
Greenwater
We also went down some of the Naches Trail and took some offshoots that were pretty challenging.
Old 06-22-2015, 07:42 PM #5
shootmymime's Avatar
shootmymime shootmymime is offline
shootmymime will become famous soon enough
you cant do this to me, Multiple times i scanned down the list of threads and saw "Shoots build thread" and got all excited like i had a new comment (doesn't happen much) then clicked on it and your popped up... Not nice.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
shootmymime is offline   Reply With QuoteReply With Quote
Old 06-22-2015, 08:00 PM #6
Just for you, I will try to calm down all the crazy excitement that is happening in my build thread
I have a 9" body lift.
Shooter's Build
Old 06-22-2015, 08:15 PM #7
Supermoney Supermoney is offline
Supermoney is on a distinguished road
That river looks high...lol
2001 Toyota 4Runner SR5 Sport
Imperial Jade Mica
231mm Tundra Brakes
5100 Bilstein / TRD / OME 890 3" Lift
285/75/16 BFG KO2s
Supermoney is offline   Reply With QuoteReply With Quote
Old 06-23-2015, 02:38 AM #8
Here's what I am up against lately. I took my 4Runner to a little offroad test spot, to try out the new suspension. It worked great. I turned on my rear diff lock to climb up a steep, gravel hill, and after that the diff lock would not disengage. I ended up driving home a couple miles with the rear locked. Since then I have taken the actuator apart and found a major problem. 3 of the magnets in the motor became loose and moved over next to each other (pic). That would cause the motor to fail. So, I got a hot glue gun and glued them back where they need to be. The real problem now... It still won't work. I've been putting it together and taking it apart all night, changing the starting position of the gear. Nothing is working.
Pics, of course...
Shooter's Build
Old 06-23-2015, 03:05 AM #9
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
Glad to see you started a build thread. Looking forward to the updates!
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 06-23-2015, 03:24 AM #10
Real Name: Alex
Real Name: Alex
I hate that... Take something apart, see what's OBVIOUSLY causing the issue, fix it, and still doesn't work.
I imagine you've tested to see if you're getting power to the actuator?
Old 06-23-2015, 03:27 AM #11
It's it's a good suggestion. Yes, it's getting power. After I cycle the switch a few times, pausing in between, I take it off the truck again and the actuator is hot.
Shooter's Build
Old 06-23-2015, 04:30 AM #12
Tyota89 Tyota89 is offline
Tyota89 is on a distinguished road
That rivers looks fun! Now just have to talk my wife into camping. So I can spend it at naches.
I need to do my rear diff mod.. puddles scares me.
Tyota89 is offline   Reply With QuoteReply With Quote
Old 06-23-2015, 02:29 PM #13
Thanks Brian. Drop in any time
It was a short little crossing which dipped the hood into the river briefly. I highly recommend extending the rear diff breather. I used a hose that is oil-safe, even though it is more expensive. O'reilly's has all the fittings, so you don't need to order from Toyota and wait for shipping. Most people run their breathers up into the fuel-fill area. I ran mine up even higher, into the rear pillar. It's a simple mod, which I put off for a while too.
Embedding didn't work. Here is the short video of the water crossing LINK HERE
Shooter's Build
Old 06-24-2015, 02:11 AM #14
I stretched my CV boots tonight
Shooter's Build
Old 06-24-2015, 03:00 AM #15
Real Name: Alex
Real Name: Alex
Wow. Looks like you're smacking those bumpstops pretty hard.
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
wyanrard's 2003 SR5 V6 build thread/picture thread wyanrard 4th Gen T4Rs 56 02-04-2017 01:03 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
