Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 01-16-2017, 02:23 PM #151
AssBurns's Avatar
AssBurns AssBurns is offline
Real Name: Steven
AssBurns will become famous soon enough
AssBurns's Avatar
Real Name: Steven
Originally Posted by Tyler James Inc View Post
I think the SS rear body mounts are a must on our rigs when you go to a stout frame-mounted bumper. Just too much give in those stock units. Bumper looks great though AssBurns 2000 Limited Build Thread
Lame about the coil bucket. Seems like a fairly involved job to fully reinforce it. Links look good. Do those transfer quite a bit more road noise that's noticeable?
The links do transfer a little bit more vibration but nothing that I think would bother people too much. Not very noticeable on the road but a little more noticeable on some washboard type stuff.
The BeerRunner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
AssBurns is offline   Reply With QuoteReply With Quote
Old 01-16-2017, 02:41 PM #152
jkeith.w's Avatar
jkeith.w jkeith.w is offline
Official Vendor
jkeith.w is a glorious beacon of light jkeith.w is a glorious beacon of light jkeith.w is a glorious beacon of light jkeith.w is a glorious beacon of light jkeith.w is a glorious beacon of light jkeith.w is a glorious beacon of light
Official Vendor
jkeith.w's Avatar
That's 2 shock tower failures I've read about in 2 days!
- guess we need a reinforcement kit?
wait - is your front strut bottoming out? shouldn't the bump stop preserve the strut tower?
keith
eimkeith.com all product descriptions © eimkeith LLC 2016-2024
e-centric.llc all content © e-centric LLC 2025
jkeith.w is offline   Reply With QuoteReply With Quote
Old 01-16-2017, 03:03 PM #153
AssBurns's Avatar
Real Name: Steven
AssBurns's Avatar
Real Name: Steven
No my strut should not be bottoming out, especially with the super bumps installed. I don't think this shock will be able to fully compress even at full bump. I'd like to make a bigger, stronger, better shock tower so coilovers can be a direct fit instead of making top hats for it.
Old 01-16-2017, 03:39 PM #154
AssBurns's Avatar
Real Name: Steven
AssBurns's Avatar
Real Name: Steven
I wonder when/ how this happened...
I guess I either need to slow down (probably not going to happen) or upgrade to long travel (probably not happening anytime soon). I'm probably just going to weld it up for now and run it until I have time to replace it. @eimkeith Hurry up and come up with that LCA solution your were talking about the other day. I think I can use it now.
Old 01-16-2017, 04:00 PM #155
Tyler James Inc's Avatar
Tyler James Inc Tyler James Inc is offline
Tyler James Inc will become famous soon enough
Oh I just saw your video and shock pictures! That's crazy how fast that cuts 1/4" wall tube AssBurns 2000 Limited Build Thread Thanks for the shock pictures too. So what's the final BS on your wheels right now? I think I would have quite a bit less room with my 5" BS wheels and 315's. Not sure though. And are those Total Chaos lower shock mounts?
Also, this is the picture I was talking about in the Panhard thread when I was talking about you cutting your quarter seams-
Is that not cut and welded?
My 2001 SR5 Ultimate Thread
My OEM+ '97 Limited Thread *Sold*
Anti-Satoshi Member #1
Tyler James Inc is offline   Reply With QuoteReply With Quote
Old 01-16-2017, 04:14 PM #156
AssBurns's Avatar
Real Name: Steven
AssBurns's Avatar
Real Name: Steven
Wheel backspacing is whatever stock 5 stars are plus 1.25" wheel spacer.
I made the lower shock mounts.
Yes the quarter seams are now cut and welded as of November. I was saying they didn't need to be cut like that to clear my 285's. I initially only cut like 1/4" up on the sheet metal to clear. I just recently cut another 1-1/4" further to make room for 35's.
Old 01-16-2017, 06:34 PM #157
jkeith.w's Avatar
Official Vendor
Official Vendor
jkeith.w's Avatar
4runner skunkwerks testpilot you are...
keith
Old 01-16-2017, 07:44 PM #158
Damn! You're all sorts of broken AssBurns 2000 Limited Build Thread
Old 01-18-2017, 11:44 AM #159
AssBurns's Avatar
Real Name: Steven
AssBurns's Avatar
Real Name: Steven
It appears to be worse than I thought. I just cut the cracks where I could and threw a bead or two down on each crack. It is not perfect nor will it be permanent but it should hold till I figure out what exactly I will do. I may, for now, make a plate for the top of the shock towers to brace it a bit. The plan is to go to coilovers soon and redo the towers to be a direct fit for the coilovers. I will warranty the LCA when I have time to swap it out since it is only like 2 months old.
Old 01-18-2017, 02:44 PM #160
JoshuaDudee's Avatar
JoshuaDudee JoshuaDudee is offline
Real Name: Joshua
JoshuaDudee is on a distinguished road
Real Name: Joshua
Talking
That suspension though!
JoshuaDudee is offline   Reply With QuoteReply With Quote
Old 01-18-2017, 08:05 PM #161
Rockdawg84's Avatar
Rockdawg84 Rockdawg84 is offline
Real Name: Sam
Rockdawg84 will become famous soon enough Rockdawg84 will become famous soon enough
Rockdawg84's Avatar
Real Name: Sam
Rebuilding shock towers, replacing LCA, etc I say cut it all off and SAS!!
84 Crawler Rockdawg84s Pic build thread but mostly pics
94 Fzj80 family hauler - sold
98 SR5 supercharged 5speed on 35's, dual locked, dual cased Smokey build Thread
03 SR5 V8, 4x4, 2.5" Icon's with 35's -Sold The Wife's 03 Build Sold
Rockdawg84 is offline   Reply With QuoteReply With Quote
Old 01-18-2017, 08:23 PM #162
derpiful's Avatar
derpiful derpiful is offline
Real Name: Hayden
derpiful will become famous soon enough derpiful will become famous soon enough
derpiful's Avatar
Real Name: Hayden
I've gotta ask, have you jumped it or anything? I'm just surprised by the cracks, I haven't really seen much of that before..
That saw cuts fast. I'm suuuuper impressed, and jealous!!
Also, I normally keep up on your build, but I missed the past two weeks or so but went back and so much happened! The bumper and links are looking sweet!
derpiful is offline   Reply With QuoteReply With Quote
Old 01-18-2017, 08:35 PM #163
AssBurns's Avatar
Real Name: Steven
AssBurns's Avatar
Real Name: Steven
@Rockdawg84
Supply me with some axles and a couple grand to get the ball rolling and I'll be more than happy to SAS. I've been debating a SAS or long travel for a while now but I just don't have the funds yet. I think I might save a SAS for a 2nd gen pickup so I can have a dedicated beater vehicle. It all depends on funds though.
@derpiful Have I jumped it? Well I have not purposely hit a jump. Have I gotten all tires off the ground at once? Yes. Way too many times as you can see.
Also I did hit a section of whoops going pretty damn fast. More than once. AssBurns 2000 Limited Build Thread
The saw is pretty awesome for sure. Sometime I think I spent too much money, then I go to use it and realize it was worth the investment.
Thanks on the links and bumper. I'm pretty stoked how they turned out as well.
Old 01-19-2017, 12:39 AM #164
Rockdawg84's Avatar
Real Name: Sam
Rockdawg84's Avatar
Real Name: Sam
I hear ya. I go back and forth about SAS. A second dedicated rig to wheel is really nice, I need to get a motor back in mine. LOL
Old 01-19-2017, 01:05 AM #165
AssBurns's Avatar
Real Name: Steven
AssBurns's Avatar
Real Name: Steven
I honestly doubt I'll ever SAS this vehicle. I'd rather keep it more of an all arounder that is comfortable for the family. I know if I SAS, I will beat it up too much. Maybe LT someday if I find a good deal on a kit. The standard LT kits on the market don't seem like they are worth the cost for the mild gain in travel.
Eventually I'd like to build something that can handle the fast stuff pretty well and the technical/crawling stuff too. I have lots of ideas and not enough money haha. I also would like to learn some CAD programs to design and build stuff more effectively.
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
Josh's Build Thread: 2000 T4R Limited "The Queen" joshespdx 3rd gen T4Rs 10 03-05-2016 02:14 PM
MrHentoni's 2000 Limited 4x4 Build Thread MrHentoni 3rd gen T4Rs 72 02-10-2016 01:38 PM
Ride_Red 2000 Limited Build Thread Ride_Red 3rd gen T4Rs 67 09-26-2014 12:12 AM
Myles' Build Thread 2000 Limited, modded resurectedvikin 3rd gen T4Rs 52 03-23-2013 10:05 AM
