Wet driver floor?
4Runner8
Was vacuuming my car and when I took out the floor mats I noticed the driver side carpet was extremely damp. No other carpet in the 4Runner was damp like this. Anyone know what it could be from?
No idea, but I had the same when I replaced my OEM all-weather mats with Weathertech. Would be interesting to see what others have to say about it.
I also have weathertech matts (the laser measured form fitted ones) and came here to see if there was an explination. I have had them installed for over a year now and the truck has seen many a heavy rain storm with no issues, been glad the mats were there!
But!
One day I parked my truck nose down on an incline and leaning a little to the drivers side ergo the drivers foot well being the lowest point in the cabin and low and behold it rains mild to heavy for a few hours I go out to my truck and there's like two inches of standing water under the pedals.
Wtf?
I carefully pulled the mat up, dumped the water and checked my floor carpet, it was dry.
Never had that happen since.
All seals and interior pieces were dry as well, carpet underneath was dry. Never did figure it out.
Leaking sunroof maybe? Mine drips and misses the seat and steering wheel and goes right to the floor.
My drain line on the sunroof was backed up and it would overflow into the cab. Cleaned it out and never have had a damp floor again.
I just had this problem and found out very quickly what it was.
First, pull your carpet back from the driver side area there by your feet. On the left side, where you rest your foot on that "pedestal", check to see if it's all rusted there - where water cold get in.
Another way to check this is look inside your driver side wheel well on the right side. There may or may not be a rust spot (hole) where water, salt, sand may have blasted through a small hole that, over time, has grown.
Also, when you have your carpet pulled back, check the floor plugs. You have two of them under the driver's feet area. Check to see if they are rusted/leaking.
Let me know what you found.
More than likely something like this is your problem:
plug1.jpg~original
or this:
DSC01298.jpg~original
and this is your fix:
DSC_7032_zpspzx6xxou.jpg~original
and 'Search' is your friend: :wink2:
http://www.toyota-4runner.org/3rd-gen-t4rs/120238-condensation-underneath-driver-side-floot-mat.html
Don't see any rust holes anywhere when pulling carpet up but it certainly is wet and gross. Smells like an aquarium :(
If you have a sunroof, that is your problem. 4 drain holes, one in each corner that need to be blown own with compressed air. Even one plugged will cause problems...
Could be water from leaking from sunroof, seals as shown, door seals. Are you sure its water ? Could be coolant from leaking heater core or if you have a manual the master cylinder could be leaking onto the floor board.
or this:
Every time I've seen a 4Runner with wet carpet or a moldy smell that was for sale, they all had some crappy Wal-Mart audio aisle crap and they were all fed through the grommet like in the first pic.
I have nothing other then stock wires coming through the firewall. No subs installed or anything that would require putting wires through it. I guess it could be the sunroof. Where are those drain holes?
My moist driver side mat was caused by a clogged front windshield drain. After clearing it out both driver and passenger sides of dirt, mud, and pine needles that had collected over 15 years my problems were gone. You should be able to peek into the bottom of the fender (near the bottom of your door) to see if there is any accumulation. I'll try to post a picture for the location I'm talking about soon.
Similar issue here. Mine was leaking through rust around the windshield. Well it still is actually! Solved it by parking in the garage
Yeah, I have Damp carpet problems in mine as well and it's either a rusty windshield framing area, a hole in the main firewall grommet or my Sunroof drains.
Or maybe a combination of all three.. who knows.
Philthyphilthy
