Roman's Runner Build/Progress Thread
Great timing on that last post by the way!
Your VW problem sounds fishy to me, entirely plausible, but fishy. Though Ive encountered some real strange VW engine problems.
As for the 4Runner, I think from the bottom is the way to go for access. Should be pretty easy up on the lift. Id be happy to help. I can't on the 27th though. Going on a few brewery tours with my dad for his birthday on Sunday. You certainly have the idea! :beer: :beer:
I could swing it this weekend if your schedule works. I wouldn't want to push you back 2 weeks staring at that annoying blinking light. It would drive me crazy! Tomorrow would work, around noon maybe?
Changed rear diff and TC oil today. I pulled maybe a quart of disgusting-looking, probably original oil out of the rear diff. I put I think just over 2qt back in.
Tackled this lil bugger today. The grommet was in there good. I managed to not drop any into the valve cover.
21779E3C-41DA-4414-B3A1-59DCB0F0CD38_zpsnunavlis.jpg~original
03620725-05FE-470B-A503-A91F6AB8C3A1_zpsbusqrxxt.jpg~original
On a hunch, I pulled my driver carpet to check for moisture on the floorboard from the most recent rain (truck wasn't driven in it) and as I suspected, the padding was damp. All 4 sunroof drains are open. The weatherstripping around the driver stood is deteriorating, and I know I have rust on the windshield frame. I suspect water is coming in through the frame, but I want to know if the weatherstripping is a more likely culprit? Doubtful, but worth asking. I don't see any sign of aftermarket wiring going through the firewall. Next is the hose and paper towel test.
5B3A5D4C-C52E-4D56-AB83-EEE5F4EAD959_zps3tqxjlon.jpg~original
CFAE0519-5452-4954-A063-76C551F9D7FC_zps8uoqz06q.jpg~original
Think I found it. The hood latch hat at the firewall grommet looked to be seated no more. Fixed it. Hopefully that fixes the leak.
D8F0885D-23A7-4528-A743-DFB99E09038E_zpsxtj4six1.jpg~original
37C5EE8F-870D-400D-B3ED-DB5AF002B99A_zpsm7vvvdk2.jpg~original
Today, with the help of [MENTION=134269]suppra87[/MENTION], the following was done.
Starter rebuilt. I don't know how this thing was starting at all.
F7C88A67-CC98-4137-95C0-0AF65D3FE411_zpscphrmex4.jpg~original
Plunger (not pictured) was replaced also.
92FA2E62-C67A-4AA3-A912-FBC01CB14AF9_zpsaislhmah.jpg~original
Front diff fluid change.
Fuel filter changed. Tim noticed that I had a fuel leak, so he rebuilt the fuel line.
32B177EF-CC48-4294-9944-C2984AB592A7_zpszvepkr1i.jpg~original
F85EB045-1010-4049-AAD5-E728B1EFCF10_zpsz21abl02.jpg~original
One coil spacer installed on the driver rear coil. This was done to fix the Yota lean. Perfectly leveled out the ride with a full tank.
536B0FF0-6CEB-458D-8200-73F80B04B336_zps09uxk0ig.jpg~original
Oh, and if you haven't looked at it in a while, check the top side of your skid plates. Scraped off a few pounds of grime.
1B333081-1E58-4502-A8D4-FB4A513DE062_zps5wv34yd3.jpg~original
5475C945-57C9-449E-A6F7-CF0210916669_zpsslc8qodq.jpg~original
If you're anywhere even remotely close to Annapolis, go see Tim if you need some work done. Great guy who knows what he's doing.
Thanks for the shout out Roman! It was great to meet you and work on your awesome truck. I hope she is running well enough to do off-roading soon!
Now just to figure out how to fix this without replacing the cover. I realize there is no fix, but I at least want to make it flat enough to be less noticeable after dipping.
45A8664C-B4F0-4AE6-9F8F-71838B2EB2D2_zps6xdq5zmh.jpg~original
All finished. So glad to get rid of that scratched and fading bright silver.
4F991F53-A649-4DFB-8914-546417376284_zpsvfyy7po2.jpg~original
4BF6473D-1209-4152-8FB5-7194C6E0BBAA_zpsayddf4gh.jpg~original
B21CE6F7-DB69-4A64-ABA4-C8412800EC58_zpsjyo9yd6c.jpg~original
9D97D9D8-5F23-475E-84D2-8EADB66205CB_zpshkubghiq.jpg~original
E7767AE8-0072-4785-9001-7F015427CDB0_zpsekqg1kpt.jpg~original
1EE76944-8D35-450D-B8E7-03B46CFDC24B_zpsaeekm48o.jpg~original
58B2D2AC-F1A3-4BDA-BFC0-3B8B7EB872ED_zpsa8juvmxd.jpg~original
152E813B-FB12-4EE7-814D-5DC22132DDB4_zps7pxsliyo.jpg~original
Newbie mistake.
476EC621-A602-4C2C-B963-357CA5EC8AB1_zps6f1gw2om.jpg~original
While no one will confuse this with a professional paint job, it's so much better than before.
94B0E7C8-FB64-4EC3-9C29-2C165B446B15_zpscpg0cliy.jpg~original
[MENTION=135299]RPS99SHO[/MENTION]
looks a lot better, i've had the same trouble trying to peel off the excess in places to so you're not alone!!!
hope you had the garage door open... that stuff can be potent while spraying
Oh yea that stuff is potent. I left the garage door open. After the first few coats I started wearing a facemask, but in the future I'll heed the suggestion of wearing an actual filtered respirator.
Daylight pics. The silver kinda looks like thundercloud. Anyone know if Runners were offered in Desert Dune/Thundercloud?
F5442EB8-351A-46CC-BBFF-3DE59415CECD_zpsy71u52ji.jpg~original
D30084DD-E6C9-4A4D-9BB8-0C172316C9D1_zpssdva9lx5.jpg~original
5E109A79-532E-4F36-8F30-1491C07F0DF9_zps0ou9amco.jpg~original
3F2958B8-1512-4A03-A54D-3AD3786CA941_zpswpxtf1bv.jpg~original
BFD91D57-0591-4420-AA7F-6F5AEFED874E_zpsbkf6gn9a.jpg~original
