I'd like to try Bilstein 5100 for my LC 7.5 wraps in the rear. The problem is that I see 2 different part numbers. The part number most commonly mentioned is 24-100144, but Sonoran Steel lists 33-187174 as the shock included with his 1.2 kit that uses the same LC coils.
33-187174 has about 1 inch longer collapsed and extended length. Is the collapsed length on this one long enough for full flex on the LC coils with original bump stops?
Which shock should I get?
Thanks!
Thanks!
