Fuel Pump carries on running.
BC4R
Quick questions, is it normal for the fuel pump to carry on running for a few minutes after you turn the engine off? Thanks
No, the pump only has power when cranking the engine or the engine is running. Are you sure it's the pump running?
Yeah its the pump nothing else in the area of the tank that makes a motor whine? Have to say today it didn't do it on a quick 5 minute drive this morning, will check again tonight after a longer drive.
Probably a faulty COR (Circuit Opening Relay). It's certainly not the fault of the pump. Give me a year and I can maybe advise a swap of relays.
If your 4runner is a later model maybe it's the charcoal canister making some noise. It's above the spare tire.
Fuel pump running
I first noticed my wive's 2011 Sienna cycling the fuel with the pump running. Since it did it when the vehicle was cold & just sitting, I thought the relay was bad. I changed the relay, but 2 days later, same thing. I just forgot about it & after a week of owning my 2016 4Runner, it did the same thing. I guess something in the computer programming cycles the fuel.
Its 1999 - thanks.
In 1999, the Power relay in the top right corner on the reverse of the fuse panel by driver's knee is the exact same part as the COR-- far right side low down under dash panel p/n 90987-02012). If you pull the COR and the noise keeps going, then it's probably not the pump, but I can't think what else it would be and I've owned a '99 for 17 years.
Thanks for the info i'll keep an eye on that relay and see how it goes.
