Old 07-15-2016, 11:38 PM #31
vester vester is offline
vester is on a distinguished road
Originally Posted by 3rzrunner View Post
i use this and i have had absolutely no leaks at 340k Kms
I second the Amsoil severe gear. Have used it for years and never had any issues.
vester is offline   Reply With QuoteReply With Quote
Old 07-16-2016, 12:01 AM #32
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
People have used cheap-o bulk gear oil for years without issues... any name brand will do the job. Don't overthink this.
Old 07-16-2016, 03:21 PM #33
swampy_swimmer swampy_swimmer is offline
swampy_swimmer is on a distinguished road
Ordered amsoil 80-90 for rear and 75-90 for front and t-case. And their grease for shaft for good measure. And their break fluid... On the side note, I was able to check the records from prev owner's. It looks like dealer did full 90mi menu on her at 91K. All fluids were changed exactly 40K ago. So I'm right on schedule.
swampy_swimmer is offline   Reply With QuoteReply With Quote
Old 07-16-2016, 05:18 PM #34
thor999 thor999 is offline
thor999 is on a distinguished road
Originally Posted by RS Dude View Post
In regards to the breather valve, I just bought a new oem breather and I tested it by blowing through it. A new or correctly functioning breater will only allow air to escape and will NOT allow air into the diff., which is good to know. I decided to replace mine at 295,000 miles because I recently replaced my rear bearings and seals and wanted to make sure everything stays perfect. Also, the breather costs less than $7!
You got that P/N?
2001 SR5 4x4
thor999 is offline   Reply With QuoteReply With Quote
Old 07-18-2016, 04:30 AM #35
TorqueOfTheDevil's Avatar
TorqueOfTheDevil TorqueOfTheDevil is offline
Real Name: Charlie
TorqueOfTheDevil will become famous soon enough
Real Name: Charlie
Originally Posted by Konkordmusk View Post
Certainly those items will wear...in the same way that seats wear, or steering wheel would wear; not necessarily an item designed to wear. The r+p certainly aren't items that one would change at regular intervals like brake pads. That is what I meant by wear item, apologies for lack of clarification.
Ahhh, ok, as in consumable items (Clutch/tyres/brakes).
Did the US 4Runner not have a friction plate LSD as an option? Or was that other markets only?
'96 Hilux Surf SSR-X Limited "The HiLex"
--VVTi 1UZ-FE--
-->Build Thread Here<--
TorqueOfTheDevil is offline   Reply With QuoteReply With Quote
Old 07-18-2016, 12:54 PM #36
RS Dude's Avatar
RS Dude RS Dude is offline
RS Dude is on a distinguished road
RS Dude's Avatar
Originally Posted by thor999 View Post
you got that p/n?
90930-03031
'96 T4R SR5 V6 Auto 2WD 336,000 miles
RS Dude is offline   Reply With QuoteReply With Quote
Old 03-15-2022, 11:20 AM #37
RunnerFanTenn RunnerFanTenn is offline
RunnerFanTenn is on a distinguished road
Wife and daughter's 4runners both over 250k, always on pavement....normal use. Have always changed differential at 75k (always looked good), and transmission at 100k (just drain and fill). Synthetic on both.
RunnerFanTenn is offline   Reply With QuoteReply With Quote
Old 03-15-2022, 11:24 AM #38
Originally Posted by DK327 View Post
I use Mobil 1 75W90 for both front and rear diff as well as transfer case with good results, no leakage, 233K miles.
Use Mobil 1 also, change differential every 75k transmission every 100k. Pavement only, typical driving....very little towing. Both runners over 250k no issues.
Old 03-15-2022, 03:32 PM #39
cdrewferd cdrewferd is offline
cdrewferd is on a distinguished road
East Coast Gear, who does a crap ton of Toyota 3rds and other gears, recommends non synthetic Lucas Severe duty. They say to spend less and just change it more often. This is what I'm running in my diffs I got from them, and will always run as I agree with their line of thinking.
Drew
99 4Runner - 35's, locker, sliders, FROR rear links, FROR skids, more on the way
07 Sequoia - family hauler
cdrewferd is offline   Reply With QuoteReply With Quote
Old 03-17-2022, 12:38 AM #40
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
I've seen their recommendation too and was going to switch to Lucas 85-140 conventional. But then I looked to see what the peanut gallery at bobistheoilguy was saying and they seem to think Lucas is pure junk. I'm just going to keep using valvoline/castrol/whatever 75w-90 conventional in everything and stop caring. The gallon jugs of conventional are way easier and faster when doing front/rear/trans in one go.
* ?rd gen. Toyota Tacoma TRD Off Road 2.4L? Supercharged ? 4x4
* 3rd gen. Toyota 4Runner SR5 v6 4x4
* 5th gen. Toyota 4Runner SR5 v6 4x4
* 1st gen. Toyota 5Runner Super Ultra Turbo Mega TRD+ Extra-medium Plus Limited 5x5
repo is offline   Reply With QuoteReply With Quote
rear diff fluid question Army97 3rd gen T4Rs 34 12-01-2022 03:22 PM
4th Gen rear diff fluid texasrock Maintenance/Detailing 12 09-29-2014 06:41 PM
Factory Diff Fluid, Regular or Synthetic? QwikKotaTx 5th gen T4Rs 5 02-23-2012 04:44 AM
Changing rear diff oil Brutus 3rd gen T4Rs 11 03-07-2009 03:03 AM
