6x5.5-8x6.6 wheel adapter question
Doc2012
So, found an individual who is selling some of the above mentioned wheel adapters.
Question is, the adapters are lug centric.
Now, if memory serves, the aluminum rims are Hub centric, and the spare is lug centric, so it should be fine to run these.
What say ye?
And yes, I plan on running HMMWV rims, with either 37s, or 35s, if I can find them.
You'll be fine with lug centric. Hub centric is like an extra reassurance that the wheel (or spacer) is centered properly but if you pay attention while putting the spacers on you'll be ok.
I want to see this happen for the record.
I had 37s on before.
I'm just unsure about recentering the rims.
Plus, the 37s could be for wheeling, and then keep stock rims for DD.
I eventually want to get to 35's...
As for centering, if youre using acorn lugnits on the spacers and you finger tighten two opposite lugs as far as you can (moving the spacer til its truly centered) you should be fine. Once the spacers are centered the wheels will be centered when you put them on.
