01-26-2022, 12:38 PM
16400-75181 Radiator: Made in Japan
There's already a few threads on this & wanted to add to the confirmation that the more expensive Toyota radiator with pn 16400-75181 (~$365) are made in Japan & comes with a radiator cap. From what my local Toyota online parts guy told me, the cheaper Toyota/Denso 16410-YZZAJ, 16410-AZ011 or Denso 221-0508 (~$150) were offered to compete with lower cost aftermarket radiators & were usually made in Taiwan. Comparing the 2, the one that's made in Japan does seem to have a better build quality & wasn't beat up during shipping compared to my older Denso radiator that's made in Taiwan. Also, the first Denso one I got years ago had a leak when I first installed it which I was able to exchange for a new one.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
01-26-2022, 12:57 PM
Does the made in Japan radiator have a proper drain port?
01-26-2022, 02:08 PM
It does. Same drain port that were on both my 3rd gens that had the original factory radiator from Japan.
01-26-2022, 03:14 PM
Wow that's fascinating, I've never heard of this. I've replaced a few 4Runner radiators and even when I went through the dealer, I got the cheaper Taiwan Denso which looked essentially the same as the original but the writing on the top was different, didn't include a cap, and obviously made in Taiwan. I also had one of those leak right out of the box but figured it was a shipping mishap.
That's wild. Thanks for the info
Originally Posted by LittleCaesar
At 5'7", I'd need a rocket up the wazoo to get in it.
But it looks good. I can't wait to see it being driven.
01-26-2022, 03:26 PM
Originally Posted by bdjcl
Last I checked, radiators for automatic 3rz & 5vz 3rd gens were the compatible.
01-29-2022, 01:00 AM
this is a pretty cool find and thank you for sharing! I've been following the conversations around where the radiators are produced over the last couple years and I though the "JAPAN" made was completely non-existent!
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
01-29-2022, 12:36 PM
That’s cool. Don’t be scared of the other one though. It’s a quality piece. That said, if this one was a known option, I would have bought it.
Even the Chinese koyo rad from NAPA I put in my ram 2 years ago was a nice piece. Chinese doesn’t always equal garbage, just most of the time…..lol.
China is capable of making great parts. They’ll build to whatever spec you want for a price. Problem is everyone likes their cheap bs…..easier to make money and most people just don’t care at the end of the day.
By the way, there’s a much higher percentage of Chinese parts in newer cars now. Start opening up Dorman and Cardone boxes….. you’ll be surprised at what you find.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
