2001 Springs fit 2001?
tbryanh
I picked up a 2001 2wd Limited. It doesn't sag in the rear like my 1997 2wd Limited does. Will the front and rear springs from the 2001 fit in the 1997?
Yes, but the 2001 springs are overall shorter than the 97's original springs. I would suggest you to get a set of new or used '99 springs if you want it a little higher. The 99 springs will raise it up a little bit and they still have the great OEM ride quality.
