Old 01-28-2019, 03:20 PM #16
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
No personal experience here, but I would remove the a-pillar cover first...
Then dremel a flat-head in there, use some heat (start with a soldering iron, hopefully you don't need a torch there...) and then try again. Heat will be the secret to softening/removing thread locker.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-28-2019, 03:59 PM #17
Lamer's Avatar
Lamer Lamer is offline
Real Name: Jake
Lamer will become famous soon enough Lamer will become famous soon enough
Lamer's Avatar
Real Name: Jake
soldering iron is a good idea. torch would definitely cause some worry. ill try this. thanks!
https://i.imgur.com/WQdryKXm.jpg
The Sequel - 1996 4Runner SR5 - Houston, TX
The Original - 2001 4runner SR5 - SOLD
Etsy Page - Custom Pinstriping and Sign Making
@8LinePinstripe: Instagram
Lamer is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 05:56 PM #18
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
If the soldering iron doesn’t work you could also try a mini butane torch, like the ones for lighting cigars. That’s what I use to solder wires lol.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 08:03 PM #19
Lamer's Avatar
Real Name: Jake
Lamer's Avatar
Real Name: Jake
dremeled some flat head into each bolt
then used soldering iron (probably 5 mins continuous heating, just to be sure)
AAAAAAAAAAAAAAANNNNNNNNDDDDDD........after a broken craftsman screwdriver and a broken drill bit, I called it quits.
I might just have to leave it as is for now. This really bums me out . I liked that handle. maybe if I get a stronger/bigger bit I can drill them out completely and weld in a nut and washer.
Old 01-28-2019, 08:50 PM #20
96RedRunner's Avatar
Die grinder and carbide burr, grind all out tap to larger screw/bolt.
Old 01-28-2019, 11:21 PM #21
T4topher's Avatar
T4topher's Avatar
Dang that’s frustrating man.. You might be able to get the bottom one with one of these.. they are what I used to get mine off but the heads were not broken off.. really have to get it on there good for it to grip when using battery impact screwdriver.
IRWIN Tools Power-Grip Screw and Bolt Extractor Set, 7-Piece (394100) https://www.amazon.com/dp/B000EF1EHY..._Lz8tCb6SX8T17
Old 01-29-2019, 02:56 AM #22
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
Remember those aren't a phillips head screw to start with, it's one of those JIS screw heads. Yes, tighten it first then go back and forth until the locktite frees up, slowly you will get half a turn, the 3/4 turn then a full turn, but go back and forth which will generate heat. If you can get a little penetrating oil under it that will help too. Reinstall with an allen head.
I can't believe how much time I wasted on those but I know when a screw is going to break so I back off and finesse it.
Wedgy is offline   Reply With QuoteReply With Quote
Old 01-29-2019, 11:54 AM #23
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
I think the threads are also an interference thread i.e. slightly mismatched so it'll create enough to keep the screw from rattling loose. I actually got mine out originally with minor trouble. It was when I went to remove a second time (didn't use any thread locker) that the head snapped off.
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 01-29-2019, 10:42 PM #24
davidch davidch is offline
davidch will become famous soon enough
I don't have any extra suggestions for the OP. However, I thought I'd take this opportunity to inform forum members of MDM, (metal disintegration machining) a subset of EDM (electrical discharge machining).
Rather than explain it all here, I'll provide links.
The ubiquitous Wikipedia entry.
Youtube videos of a guy in LA who does this kind of stuff for a living. His web site is shown on the video.
See here what he does with a badly botched BMW cylinder head. Of course, no reader of this forum would ever botch a repair so badly.
A maker of the equipment.
MDM and EDM seem mostly used on pieces you can lug to a shop and put on the table. Not suitable, so far as I know, for a screw stuck in a vehicle's A pillar.
I live near Seattle. 15 years ago I had a 6mm bolt broken off in the aluminum gas tank of a motorcycle , I called area welding shops until I found one (in Kenmore) that had an EDM machine. They cleanly burned out the screw. The cost was $25.
davidch is offline   Reply With QuoteReply With Quote
bolt , broke , easy-out , fix , grab
A-Pillar grab handle bolts. dustxking 3rd gen T4Rs 43 10-26-2020 02:45 PM
Front Driver side A-pillar Grab handle? Brad2064 5th gen T4Rs 22 05-29-2019 01:14 PM
Driver side a-pillar grab handle? dedonderosa 5th gen T4Rs 30 05-04-2019 02:10 AM
A pillar grab handle seadog1022 General Discussions 0 01-13-2010 09:37 AM
A-pillar grab handle is back! (oops - nevermind) GatorGreg 5th gen T4Rs 13 08-19-2009 09:11 PM
