Old 12-15-2019, 08:51 PM #76
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
High beam setting.
Old 12-15-2019, 08:52 PM #77
AndyMonroe AndyMonroe is offline
AndyMonroe is on a distinguished road
I've been welding frames like that on toyotas, damn
AndyMonroe is offline   Reply With QuoteReply With Quote
Old 12-15-2019, 09:03 PM #78
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
After I quick drive. I realized I had to adjust the headlights down so I didn't blind other drivers. So I just adjusted down and all is well. Basically just aimed them at the bottom panel which sets my headlights about 25 ft out on front of me and I made the drivers a few clicks towards the passenger light. Very pleased with the lights.
H4 LED Fanless Headlight/Fog Light Conversion Kit with Adjustable Color Temperature and Compact Heat Sink - 5,000 Lumens/Set | Super Bright LEDs
Old 12-15-2019, 09:04 PM #79
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Have any photos?? I always love to see patching.
Old 12-15-2019, 09:22 PM #80
Joppo99runner Joppo99runner is offline
Joppo99runner is on a distinguished road
Nice looks good man!
Joppo99runner is offline   Reply With QuoteReply With Quote
Old 12-15-2019, 10:25 PM #81
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Nice job on the bulb replacement and thanks for sharing the links.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 09:41 AM #82
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I would imagine the bulbs make the newer style of lights brighter too. However, I didn't test this theory out yet. I am just glad I can see the road again as it was getting pretty bad with all the newer cars lights. Especially bad when it rained on back non lines road.. I report back in a few night drives in.
Old 12-20-2019, 07:39 PM #83
I don't have any pictures but I did not patch, I changed parts of the frames.
In east KY.
Old 12-20-2019, 07:48 PM #84
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
In east KY.
That will work too. I Like to take what is there and fix it. Nothing wrong with chopping the frame and welding it back together. The end result is a solid frame and that is what matters. Do you take out all the holes in the frame when you change it or leave those factory holes in place?
Old 12-21-2019, 01:43 AM #85
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
You’ll love the LED’s. I run the Beamtech led’s with fans. I had to add a resistor for my high beam indicator to work.
I also had to aim my lights a bit lower. People would flash me often.
They are much better than the $40 silver star ultra standard bulbs.
The one negative, also a positive, is they light up reflective signs way out, but a bit too much if it’s a white speed limit sign. They are too bright when your close.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 12-23-2019, 08:53 PM #86
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes they do. I probably have to do some a few more slight adjustments. I actually dropped my lights a full garage panel down so people wouldn't flash me. I am just wondering if these are wired properly as I read that our Neg wires in our headlights are different then the normal socket. If this is the case, I will create jumpers to change the wiring instead of changing the plugs. I love the fact. I can just pull a bulb out and swap back to original OEM Lights. Not that I ever plan to. Its just in case a cook an LED.
I will check with super bright LED as the box doesn't show me any wiring or pin configurations.
Old 12-24-2019, 08:31 PM #87
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I changed my windshield nozzles several weeks ago. Replaced my oem 2 with a rav 3 nozzle. However, I didn't adjust the nozzles until yesterday. That's alot better 3 position hits.
Old 12-24-2019, 09:53 PM #88
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Yes. That's a good upgrade. I still get excited and tell the wife '3 streams!!'. She tells me to shut up and drive.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 11:10 PM #89
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Lol.. They have no idea how much better that was then the 2 streams narrow band.
Old 12-28-2019, 08:42 PM #90
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well my original started leaking about 3 years ago. So I had it replaced with a remfg one. Then about 3 days later the nipple rotted through on the return line and the fluid leaked out. I kept filling it but the damage was done and that new pump worked but was noisy. Got that fixed and just listen to that pump whine for a few years.
I bought a used replacement of a forum member. So Today I cleaned the screen in the reservoir on the replacement OEM pump and changed it.
It's nice to have a power steering pump that's quiet again.
chassis , frame , repairs , rigs , road
MORE 3RZ builds....... ralatkins 3rd gen T4Rs 21 10-28-2022 12:39 PM
Trailer Builds Okki 5th gen T4Rs 6 12-15-2019 09:11 PM
Vehicle Builds Victory 4x4 Victory4x4 4 06-19-2019 08:44 AM
5th Gen Pre-Runner builds? PeoplecallmeIan 5th gen T4Rs 0 03-14-2018 04:34 PM
