Old 03-15-2020, 01:39 PM #1
noxor noxor is offline
noxor is on a distinguished road
Changed spark plugs, now misfiring when warmed up
99 3.4L 4x4 automatic here. 145k miles.
I changed my spark plugs from the single ground to the double ground NGKs.
Next day I drove an hour and it was fine. I started it up to go home and it was idling rough. When I got back home I had error codes for cylinders 3 and 6.
I have replaced the spark plug wiring harness and that seemed to work until I was an hour down the highway and it came back (it was bad enough to cause check engine light to flash and I have AAA so i got towed home).
What should be my next steps?
noxor is offline   Reply With QuoteReply With Quote
Old 03-15-2020, 02:00 PM #2
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
Coils and wires
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 03-15-2020, 02:31 PM #3
rkntoy's Avatar
rkntoy rkntoy is offline
rkntoy will become famous soon enough
rkntoy's Avatar
Since it was running OK for an hour I would double check and make sure something didn't shake loose starting with cylinders 3 and 6.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
rkntoy is offline   Reply With QuoteReply With Quote
Old 03-15-2020, 02:38 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Spark Plugs Wires and Coil Information for the 5VZ-FE
Old 03-15-2020, 03:06 PM #5
Tucson Mike Tucson Mike is offline
Tucson Mike is on a distinguished road
Did you buy the plugs from a reputable seller? I recently ran into a similar issue where I bought plugs (denso) off ebay for my sequoia and they were counterfeit. Immediately #8 started misfiring and I replaced just that plug. All was well for about 15k until I got multiple misfire code and did more researching and discovered mine were counterfeit. If your vehicle was running fine before you put the new plugs in and the wiring is routed correctly, I would look at the plugs being defective. Good luck Mike M
Tucson Mike is offline   Reply With QuoteReply With Quote
Old 03-15-2020, 04:15 PM #6
4restGump 4restGump is offline
4restGump is on a distinguished road
Yep, my money is on the counterfeit plugs. Take a picture of them for some lol
4restGump is offline   Reply With QuoteReply With Quote
Old 03-15-2020, 05:53 PM #7
I guess the real question is where did he buy them from.
Old 03-15-2020, 06:39 PM #8
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I would put two old plugs into Ctls 3 and 6. Note those two are on the same coil, so one bum plug can cause both to misfire.
My Backyard Frame Swap
Old 03-15-2020, 08:28 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes. I am suspecting bad parts as well. I added a youtube video on NGK plugs. Everyone should watch it as the counterfeit plugs are extremely close to the real plugs.
They were even bought on Amazon so not from a clean source. Its amazing to the extent china goes to. No reason for counterfeit parts.
Old 03-16-2020, 02:21 AM #10
Thanks Mike and everyone else! I bought the plugs from rock auto and they match the pics online (made in japan etc).
I pulled them all, gapped them to .044 (they were .040), and installed to 13 ft/lb per spec. I had originally hand tightened them and then added some with a wrench before but after using a torque wrench I definitely didnt apply as much pressure earlier. I am thinking it was simply loose plugs.
I ran it for a while tonight, and will take it to work this week, but so far so good now!
Old 03-16-2020, 02:22 AM #11
Yep I think this was it. I dont think I had torqued them enough!
Old 03-23-2020, 09:48 PM #12
Well I spoke too soon. An hour into a drive the problem came back.
Put in new spark plugs I got from autozone and the problem persists.
Am checking coil packs out and then will move onto distributors etc.
Old 03-23-2020, 10:26 PM #13
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Sounds like a bad coil to me. I would swap the coil pack from one cylinder to another and see if the misfire moves around. Pretty quick swap. If it's stays on the same 2 cylinders, then you may have an issue with the wire to the coil pack.
FYI - there is no Distributor on these engines.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 03-23-2020, 11:43 PM #14
Joe-Runner's Avatar
Joe-Runner Joe-Runner is offline
Real Name: Joe-Runner
Joe-Runner has a spectacular aura about Joe-Runner has a spectacular aura about Joe-Runner has a spectacular aura about
Joe-Runner's Avatar
Once upon a time I changed the spark plugs in my 1999 Mercury Cougar. Ran pretty all right except it would hesitate under significant acceleration. Finally, after a buttload of troubleshooting, I traced it down to a cracked spark plug...... could be your issue...
2021 ORP, Naut Blue, sunroof, Gunmetal TRD wheels w/265 Falkens, NFAB steps, 1.75" 5100s front, 1" Cornfed spacer rear / 2̶0̶1̶3̶ T̶r̶a̶i̶l̶, K̶D̶S̶S̶, / 2̶0̶1̶7̶ O̶R̶P̶
https://badges.fuelly.com/images/sig-us/1038471.png
Joe-Runner is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 09:45 AM #15
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Do you have the ability to test the plug wires and coils with a meter as I commented earlier on this thread? That may help in narrowing the issues down quickly. :-)
back , ground , home , hour , spark
changed spark plugs today caper 5th gen T4Rs 10 01-06-2020 05:55 PM
Changed spark plugs on 4Runner (4.7-V8); progress4m 4th Gen T4Rs 2 12-12-2014 02:30 PM
Changed my spark plugs and found this. JB_Runner 3rd gen T4Rs 10 11-25-2013 01:31 PM
Changed spark plugs... One was covered in wet oil... 1clean4runner 4th Gen T4Rs 53 01-22-2013 02:08 AM
Changed spark plugs and found oil on some of them? T4R2003 4th Gen T4Rs 2 10-23-2009 01:12 AM
