SRQ Fabrications Fender Flares?
I was actually looking at these as well. My runner got into an accident and the original fenders were banged up pretty bad. Instead of trying to rebuild them I wanted to see if these would line up with the rest of my limited cladding.
Sent from my SM-N975U using Tapatalk
Hi guys
These flares were designed for the flareless trucks. Namely because my truck had no flares and was the vehicle I used to build the original flares which we made molds of. We just finalized them and are now on v3 of the molds. They sit 4.5" wide and are installed with rivnuts and bolts. You can mount them higher if you have body line cuts to clear 35's etc. As far as fit etc, this is meant as a custom body add on. It is not a simple oem style bolt on in anyway. Its like installing a wide body or fender flare kit on a car. You may want a professional to handle the install for you. We leave enough material on the edges to be shaved/trimmer to fit as you move up and down the body line.
So we ended up ordering a set of the Carbon Fiber wrapped version of these from Andrew (BX_Built owner). So looking forward to fitting them on! He was great to chat with and answered all of my question promptly. Great customer service so far!
