Hello all,
My car was running a little hot (about 200 on highway and 210 in the city), so I decided to tackle the thermostat and coolant.
I found that they had previously used an aftermarket thermostat. I also found a lot of rust and corrosion in the coolant reservoir. Upon further inspection, I realized the tubing for the coolant reservoir was completely filled with rust, and water could not flow through. The coolant itself wasn't terrible, so I hope most of the rust got 'filtered' and trapped in that reservoir.
I implore you guys to check out / clean your reservoir tank and tubing. I would also avoid non-OEM thermostats. After installing the new thermostat with the jiggly-wiggly valve down, the car idles around 192.
Hope this helps someone.
