Old 07-13-2020, 11:29 AM #1
MrEMan's Avatar
MrEMan MrEMan is offline
Real Name: Emory
MrEMan is on a distinguished road
MrEMan's Avatar
Real Name: Emory
Removing stripped seat bolt
The front left seat bolt on the drivers side in my 02 is cross-threaded/stripped … the seat wobbles and I can't back it out or screw it any further in. Any thoughts on how best to remove it?
2006 4Runner Sport Edition V6 4WD - Shadow Mica
2005 4Runner SR5 V6 - Titanium Metallic
2004 Sequoia SR5 V8 4WD - Natural White w/ Silver Sky Metallic cladding
2002 4Runner SR5 Sport V6 4WD - Black
Yes, I still own all four ...
MrEMan is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 11:35 AM #2
spartacus's Avatar
spartacus's Avatar
Use a small flat pry bar or a' flat screw driver and apply upward force on the head of the bolt while loosening it.
Old 07-13-2020, 12:19 PM #3
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Actually, on that particular bolt, this may not be the best approach. It's probably not stripped, rather the thread has corroded and the weld-nut has broken free from the sheet metal of the floor contour it is welded to. This is pretty common. You can try the pry bar, but it probably won't work and if you force it hard with the pry bar, you will just rupture the sheet metal and do more damage to the floor. Pressure with the pry-bar is unlikely to secure the nut if the sheet-metal could not hold it,
There is no easy way. I would try to dremel the head of the bolt off. You could also drill the head off, but it might spin on you. If you have to, then just go violent and just pry the base up without trying to turn the bolt until the nut busts through the sheet metal. Then you still have to cut the bolt out of there.
The fix is easy. Just get a longer bolt and drill through the lower floor and put a nut and a big fender washer on the underside of the truck. Cover with RTV to seal. That's worked fine for me and many others.
Some people of the OCD persuasion have welded in new sheet metal or inserted a new nut through a slot cut into the side of the contour. Search and you will find them.
My Backyard Frame Swap
Old 07-13-2020, 02:01 PM #4
MrEMan's Avatar
Real Name: Emory
MrEMan's Avatar
Real Name: Emory
Thanks … I've already tried prying up on the head of the bolt with no luck. The explanation of the weld-nut breaking free makes a lot of sense. I can definitely cut the bolt with a Dremel, but was concerned about how I would get the remaining portion out. Sounds like cutting it out is my only option (other than just ripping it out, which would probably cause more damage).
Old 07-13-2020, 03:34 PM #5
TheDurk's Avatar
TheDurk's Avatar
You can just leave it, or fish it out with a magnet if you are lucky.
Old 12-04-2020, 10:33 PM #6
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
the welded nut for my driver's seat is now loose and was wondering if somebody could kindly measure the original center-center spacing of the two front bolts of the driver's seat? the seat frame on mine is wiggling so i can't base the correct measurement on the seat frame.
i'm planning to weld a nut to a piece of sheet metal and weld it to where the nut was originally welded.
Thank you.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 12-05-2020, 09:37 AM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
From the center of the other hole and from the pinch weld of the rocker.
Old 12-05-2020, 08:59 PM #8
4runnerfiend's Avatar
4runnerfiend 4runnerfiend is offline
4runnerfiend has a spectacular aura about 4runnerfiend has a spectacular aura about
my bolt ripped out due to sheet metal fatigue. I posted my solution here. hope it makes sense.
Front seat bolt thread ripped out of floorboard
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
4runnerfiend is offline   Reply With QuoteReply With Quote
Old 12-05-2020, 09:09 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I welded mine to a washer then drilled and pop riveted it in. I would weld it in after in place though. Pop rivets can wiggle some ad welding is solid. That crossmember the nuts are welded to inside is kinda on the thin side. These nuts never should tear through. Design flaw.
Old 12-06-2020, 04:02 AM #10
Thanks man! Appreciate it!
Old 05-07-2023, 04:44 PM #11
sneezye sneezye is offline
Real Name: Ben
sneezye is on a distinguished road
Real Name: Ben
Does anyone know what size the seat bolt is? I need to order a tap & die to fix boogered threads. Looks like it might be M10x1.0.
2002 Limited
Golden Pearl
sneezye is offline   Reply With QuoteReply With Quote
Old 05-08-2023, 10:33 AM #12
blairracd's Avatar
blairracd blairracd is offline
blairracd is on a distinguished road
blairracd's Avatar
Odd. I have an issue with this same bolt. It just spins freely and I cannot screw it further in or out. Even with apply upward pressure.
Living and breathing and bleeding Toyota
https://imgur.com/a/KvwQdyO
RIP my ‘96.
blairracd is offline   Reply With QuoteReply With Quote
Old 05-08-2023, 12:25 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The nut in the back came loose. Hence why it's stripped..
Old 05-09-2023, 09:40 AM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I have to check. Probably be a few days.
Old 05-17-2023, 09:18 PM #15
TheDurk's Avatar
TheDurk's Avatar
That bolt is p/n 90119-10825 *** STD. PART. The 10 right after the hyphen means it is an M10. Toyota M10s are usually 1.25 thread. This list has never done me wrong:
There are four primary considerations for spare bolts and nuts: (1) diameter, (2) pitch, (3) class (strength rating), and length (bolts only). Toyota was nice and standardized on only one pitch for each thread diameter, as follows:
6 mm diameter - 1 mm pitch (iso course) - requires 10 mm wrench to fit head / nut
8 mm diameter - 1.25 mm pitch (iso course) - requires 12 mm wrench to fit head / nut
10 mm diameter - 1.25 mm pitch (iso fine) - requires 14 mm wrench to fit head / nut
12 mm diameter - 1.25 mm pitch (iso other) - requires 17 mm wrench to fit head / nut
14 mm diameter - 1.5 mm pitch (iso fine) - requires 19 mm wrench to fit head / nut
16 mm diameter - 1.5 mm pitch (iso fine) - requires 22 mm wrench to fit head / nut
bolt , removing , screw , seat , thoughts
Rear Seat Bolt Stripped - HELP TheDozer 5th gen T4Rs 13 05-15-2018 01:43 PM
stripped bolt hole eanema 3rd gen T4Rs 15 11-20-2015 08:28 PM
Top hat bolt stripped help! Chubbs22 3rd gen T4Rs 3 09-30-2014 02:41 PM
Help stripped head bolt 22R AKcharger Maintenance/Detailing 3 01-06-2013 12:58 AM
Stripped bolt chunderboy Off Topic 7 06-04-2005 01:23 PM
