Originally Posted by Bad Luck
I've been looking at body lifts lately. What size did you go with? Any problems or tips for install?
I went with Fat Pats 1” body lift.
I used a ton of Energy Suspension Super Lube (super sticky silicone paste) and re-lubricated all my poly bushings.
Everything went well, except I’m not fully sure about the rearmost mounts. It seems like the bolts are too long. I’m not sure. I’m still investigating it and I’ll post my findings if/when I figure it out.
Tips: it’s easiest with at least one other set of hands and eyes. Get maybe a 4’ length of 4x4 to place along the pinch weld as you jack up the body. Do one complete side at a time (we did driver side then passenger side).
Don’t forget to loosen your trans shifter linkage and steering joint before jacking up. The hardest part was the steering spacer, but it’s not too bad.
