Original factory key Fob question
Sarki
Photo tells it all.
Anybody have a working fix so I can attach this to key chain and not lose it.
Hate to retire a fully functioning factory key fob.
Photo tells it all.
JB Plastic Weld ? Maybe if you could cut a small piece of plastic from something like a pen cap or something, you could JB Weld it together.
I had this happen to the key to my 2003 Matrix.. wish that loop was reinforced.
You can always go with something like this. I believe someone else makes a similar product. I haven't used either one myself, but they seem to have generally good reviews.
Edit: Found the other one I've seen used. Link
Do a search. Another member has an awesome solution by keeping the board and placing it in a different awesome casing.
Photo tells it all.
A couple of us use and like these AJT DESIGNS
Just pop your guts into one of those stylish and durable fobs. Housing and screw color options are up to you.
I bought a key fob case on amazon for less than $15 and it's been fine. Just swap over the case if it comes with the new motherboard.
I bought a new shell identical to my old one off of Amazon for $7. Swap out the guts throw in a new battery while you are there and it’s like brand new!
Go to advance and get a new case. [emoji2369]
Or the rubber boot thing for it.
