Old 11-19-2021, 05:27 PM #31
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by fatherohenry View Post
I just watched Tim's timing belt video again and now realize that the cam seals are behind that backing plate so it's entirely possible the left seal is leaking and I just didn't see it. Guess I'm preparing for a timing belt job. Just bought the crank and cam pulley holder tools and will order the seals in the morning. Or do I just order aircabinman and replace everything since the guy used a Duralast kit to begin with? If it were June that wouldn't even be a question.
If you have the funds to do it I would order the aircabinman kit. I'm not a fan of anything duralast. If the last guy replaced the crankshaft seal I would get one of those as well. Better to have it and not need it than the other way around.
Old 11-19-2021, 05:48 PM #32
fatherohenry's Avatar
fatherohenry fatherohenry is offline
Real Name: Mark KN6TZI
fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough
I actually just ordered the complete kit. It's only money and I've never seen a luggage rack on a hearse anyway.
'96 T4R SR5 | 4WD | Auto | 199 TBU | 268k+
fatherohenry is offline   Reply With QuoteReply With Quote
Old 11-19-2021, 09:18 PM #33
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Its very possible that cam seal is the leak. I haven't heard of a oil pump leaking.
I only use Airbcinman kits.
If its #1 or #2 timing covers where you are seeing it. I would suspect that cam seal as its would like down and behind the plate then over when if it hits water pump and out directly where you are seeing it.
Old 12-02-2021, 04:47 PM #34
Before diving into that minor timing belt job I finally realized the mirror in my toolbox might be of use. Yeah, I'm on the ball like that.
I know I'm new at this but it doesn't look like a cam or crank seal leak to me.
As the VCGs were done 7 months ago but not the plugs or half moons, is there any situation where re-using the valve cover gaskets would be acceptable? That's $65 I could easily spend elsewhere.
Right cam plug/half moon:
Left side:
Old 12-02-2021, 07:13 PM #35
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If the vale pan gaskets is fairly new and soft. I think it would reseal... Let's see what the others say?
Old 12-03-2021, 12:44 AM #36
Real Name: Patrick
Real Name: Patrick
I think you would be fine reusing the valve cover rubber gasket and the intake manifold gaskets. I’ve reused a lot of rubber valve cover and intake gaskets without issue. Since yours are pretty new they should be soft and supple enough to seal correctly.
dyed , leak , learn , oil , work
Transfer Case Actuator Leak - Fix OPTIONS & Thoughts da1dp 4th Gen T4Rs 30 05-23-2023 09:27 PM
Oil leak and "rumble strip", thoughts? BagiMT 4th Gen T4Rs 3 12-05-2018 04:24 PM
Coolant Leak - any thoughts?? t4rain 3rd gen T4Rs 6 06-06-2016 11:25 PM
Coolant leak solution, pepper, eggs or liquid aluminum stop leak? BUGSEY General Discussions 1 01-30-2014 01:32 PM
Thoughts on where this leak is? kobusLifeRemotely 3rd gen T4Rs 4 02-07-2012 01:26 PM
