11-22-2021, 08:29 PM
MF cat conv good for NYS INSP?
MF Cat. Any luck with NYS inspection? Getting conflicting information. Primarily for those who have to pass NYS insp. Thanks.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
11-22-2021, 11:05 PM
If it has a CARB number on it, and is certified for your specific engine family it should pass. Is your rig CA or 49 state emissions?
11-22-2021, 11:33 PM
Hey There,
I believe at one time i was told that it's a California emissions. I don't know how to tell myself. Is it hard to determine?
Thanks.
Currently 194K
Cheers
11-23-2021, 03:12 AM
Originally Posted by giguchan
Hey There,
Thanks.
I think it says on a sticker on the hood but also if you get underneath and check if you have 2 catalytic converters (CA spec) or one (fed spec)
11-23-2021, 04:29 AM
I have one CC but 2- 02 sensors.. so i guess i have fed spec. thanks for the reply.
Currently 194K
Cheers
11-23-2021, 05:07 AM
There should be an emissions sticker stuck to the underside of the hood.
Having two O2 sensors isn’t the way to tell.
11-23-2021, 09:41 AM
Real Name: Patrick
Real Name: Patrick
Federal and California emissions will both have two sensors. Federal has one catalytic converter and california has two catalytic converters.
11-23-2021, 10:19 AM
I'll have another look under the hood then. Like i said i was told that by someone who knows more than me.. I'll have a look for the sticker. I'll report back with my findings.
Currently 194K
Cheers
11-23-2021, 11:28 AM
Hey There,
Thanks.
Put your VIN into Toyota's official vehicle spec website, Vehicle Specification | Toyota Owners, and see if it tells you anything.
When I put in my VIN, I can see "RE 48 STATE EMISSIONS" under the "PORT OR FACTORY INSTALLED EQUIPMENT" section.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
11-25-2021, 08:12 PM
Bad News for me eh?
AI PREFERRED EQUIPMENT #1 Factory
C7 CONVENIENCE PACKAGE INCLUDES Port
CA CALIF. EMISSIONS REQUIREMENT Factory
CD REAR CARGO COVER Factory
CF CARPET FLOOR MATS Port
CK ALL WEATHER GUARD EQUIP PKG Factory
FN FENDER FLARES Port
FS FRONT SPORTS SEATS & SPORT FABRIC TRIM, CRUISE CONTROL LEATHER COVERED STEERING, WHEEL AND SHIFT KNOB Factory
RB RUNNING BOARDS Port
RH REAR HEATER Factory
SR POWER TILT & SLIDE MOONROOF Factory
WL WHEEL LOCKS (ALLOY) Port
Currently 194K
Cheers
11-25-2021, 09:41 PM
Real Name: N/A
Real Name: N/A
Looks like you have CA spec. I have a 49 state vehicle registered in CA with no issues smogging, but that still has the OEM cat.
1998 4runner 2.7 manual
11-25-2021, 11:19 PM
Yeah i thought so..
I have a CEL which points to the sensor. i'll change it and see what happens next.
Thanks
Currently 194K
Cheers
11-26-2021, 01:33 AM
Real Name: Jerod
Real Name: Jerod
The CA emissions vs Federal emissions labelling is inconsistent. You can put a CARB (California smog approved) cat on a Federal emissions 4Runner, and a Federal emissions cat on a California emissions 4Runner. I live in California but drive and own a Federal emissions 4Runner which passes smog with a CARB approved Magnaflow cat with no issues whatsoever. Confused yet?
Just buy what's cheapest and allowed by your state. Last I looked, NY has adopted the CARB standards so I believe that means you would need a 50-state catalytic converter.
11-27-2021, 03:39 AM
Hey,
Thanks for the reply. I was just doing some "pre research" I don't know for sure if it is in fact the CC I was preparing for the worse. It sort of looks like the worse might not be so bad.
I crawled around under there and i swear i saw only one CC and a rusted sensor. Lets say i did have 2 CC'S would they both follow down the passenger side? I had the MF Overland installed in August
so if i did need a CC i would go with the MF.
Thanks.
Currently 194K
Cheers
11-27-2021, 10:40 AM
The 97 puppy hauler was from new jersey and was a cal spec single cat.
