Temp control ?
NCrunner0
I have a 00 4runner limited with the ATC that I am having some issues with. When I turn the temp knob it adjusts properly, from cold to hot, but the air coming out of the vents stays hot until I turn the "cold" mode, then the air cools off. Example- at 66 its hot, at 75 its hot, its cold only at "cold" setting. Im sure someone has had this trouble before, any info much appreciated!!
Sounds like your climate control unit is on the fritz. You can have it repaired by a member of this forum.
This is John's thread regarding repairing these units for people: Auto Climate Control Repair Services
You can email him as well: [email protected]
Here's a video we made about this topic:
<iframe width="560" height="315" src="https://www.youtube.com/embed/rN0pHmZWTdU" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
I just had it repaired, I was thinking that would take care of too it but no such luck!!Temp and fan adjust properly when turned its just the actual air coming from vents doesnt. I will def watch Johns video though!
Maybe the blend door actuator isn't operating properly.
Here's a link to a 2000 EWD (electrical wiring diagram): Dropbox - 2000 4Runner Electrical Wiring Diagram (EWD383U) - Printable - Simplify your life
Here's a link to a 2000 FSM (factory service manual): Update your browser to use Google Drive, Docs, Sheets, Sites, Slides, and Forms - Google Drive Help
If you go to section 236 of the EWD that will show the wiring diagrams for automatic climate control. Judging by the wiring diagram I would say you have a problem with the room temperature sensor, the wiring for that sensor, or the ac amplifier itself. From my understanding of the system the ac amplifier sees what temperature you have selected and what temperature the vehicle cabin is, and then calculates where the blend door should be. The exception to this is when you select full cold or full hot. I'll attach a picture from a 2000 FSM that shows where these components are located.
Thanks Bad Luck! I think you are on to something. I removed the servo motor that is moved when you adjust the temps, took it apart, cleaned and inspected and everything looked good. Re-installed and the unit is doing the same thing, so I will research these items you mentioned!
I can find the ambient temp sensor but not the room temp sensor, anybody have a part number or is it called by another name?
