Old 12-14-2021, 11:24 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Rust on 3rz-fe cam shaft
There is rust on the cam shaft lobes. I barely know how well this engine was treated, but the last owner wasn't super ideal to say the least.
There is rust on the cam lobes, the timing chain tensioner seems pretty far out too. The engine is 23 years old with 177k. The dark spots in the photo aren't oil, they are corrosion.
Link to album
1998 4runner 2.7 manual
Last edited by Pyral; 05-16-2023 at 02:56 AM. Reason: Maintaining photos (link rot)
Pyral is offline   Reply With QuoteReply With Quote
Old 12-14-2021, 11:43 PM #2
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
The dark stuff is just varnish. It actually doesn’t look bad — no sludge or deposits. Just some stain from slightly over long oil changes. A few fills of full synth (diesel spec is best) may reduce it over time.
Try to count the exposed teeth on the tensioner. It looks about how mine does but it’s hard to tell.
JZiggy is offline   Reply With QuoteReply With Quote
Old 12-15-2021, 12:01 AM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Are you talking about that orange coloration? You realize that's just varnish right? Pull the covers off any valvetrain of similar age/mileage and it'll look very close to the same, especially if they use conventional oil. The only way they could possibly rust is if water entered the valvetrain and the engine sat until it fully dried out, in which case you would've notice a lot more problems before now
The spark plug wells aren't super uncommon; just how they seal up. Moisture gets in one way or another but can't get out
Edit: screeenshot of how my 5VZ cams look to give an idea. PO used lots of dino fluid
Rust on 3rz-fe cam shaft-screenshot_20211214-200206_snapchat-jpg
Old 12-15-2021, 02:59 AM #4
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I've owned it for 12k miles and I've probably done 3 or 4 oil changes, 2 with synthetic oil. I think an seafoam oil treatment might be in order. I think your right about it being varnish, but there is definitely corrosion on the inside of the valve cover.
The sparkplugs had a good seal, really struggled to pull them out the first time, now they come out easily. I think the coils were replaced at some point, they aren't numbered annoyingly and they don't have a date on them like the stock ones do.
For some reason my denso spark plugs had this neoprene ring around them, IDK if its from the after market coils, but this neoprene stuff was falling apart and its resting on the lip where the spark plug usually sits. I'm worried I might get shreds of this neoprene substance in my cylinder. Should I worry?
Oh and I counted the teeth on the timing chain tensioner. I think there was 10 or about that. Anyone know how many teeth there are total?
Answered my question: there are approximately 20 teeth on the tensioner total. So I'm at half life. Had to pause and count teeth on this video.
Old 12-15-2021, 11:14 AM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
It's all varnish. There is no corrosion on the engine internals or the inside of the valve cover.
I have a different engine but none of my spark plug coils are numbered or marked from the factory.
The neoprene stuff you are talking about isn't an issue. If you really want to you can vacuum it out with a shop vac with a smaller diameter rubber hose (heater core hose works good if it will fit) duck taped to the shop vac hose to reduce it down.
Old 12-15-2021, 11:54 AM #6
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
If you're talking about light pitting here and there that isn't corrosion nor uncommon with older vehicles that have potentially been neglected at one point. Very common with age regardless. I don't see how steel would corrode in the presence of oil unless you're using straight crude
Old 12-15-2021, 11:59 AM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The steel internals only rust if an engine sits a long time without running or being spun to coat the parts with oil.
Old 12-15-2021, 03:51 PM #8
Looks like a great engine. The only (incredibly minor) corrosion I saw was on the inside of the spark plug tube. Still not an issue.
Do the next couple oil changes with Rotella T6 and your engine can look like this inside (250k miles of dino oil, then 20k of T6):
You can see the varnish is still getting cleaned up, but much of the engine is quite nice already.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-15-2021, 04:16 PM #9
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Looks great. I'm a newbie, please tell me more
- What weight are you using with Rotella T6?
- Synth?
- All 5.5 quarts of Rotella? Or a blend?
- Any side effects or anything to watch out for?
- cat converter damage over time?
- temporary cleaning tactic? or run Rotella forever?
Thanks
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 12-16-2021, 03:39 PM #10
TravThePro's Avatar
TravThePro TravThePro is offline
Real Name: Travis
TravThePro is on a distinguished road
TravThePro's Avatar
Real Name: Travis
- Synth?
Thanks
I would run the 5-40 for the Rotella T6 and all of the Rotella T6 is synthetic. Just use the T6 and don't bother blending it with anything else. If you already have oil leaks then they can become worse with the detergents eating away all of the buildup blocking them off. The only way you will damage your catalytic converter with oil is if your engine burns a ton of oil (worn valve seals or seized/worn piston oil rings). Using T6 and other high detergent oils have actually helped with making this problem less significant in the past for a few older/neglected engines we have used it on. I know people who run it once every 2-3 oil changes and people who refuse to use anything but the Rotella T in their engines. Seeing the additives in T6 I would say that it is completely safe to run it long-term in our engines. The most important thing with running a high detergent oil after potential long-term abuse on an engine (you have no idea how the PO took care of it) is to use a really high-quality oil filter.
1996 T4R
TravThePro is offline   Reply With QuoteReply With Quote
Old 12-16-2021, 05:25 PM #11
^^^ That about covers it.
I run it fully time on my older engines (ones that originally called for 5w30 or 10w30), 5w40 weight. Whether you want to do that is up to you. There is some theoretical chance of cat damage, but I haven't seen it yet (and pass CA smog every two years).
cam , engine , lobes , rust , shaft
Can I use rust reform on a small body dent with rust? Nooga_Rock Maintenance/Detailing 3 05-18-2020 02:58 AM
Propeller Shaft = Dealer Shaft tahoekarl 5th gen T4Rs 31 01-24-2020 02:51 PM
Any rust issues on Gen 5? Beach rust prevention. Fomer_FJ_owner805 5th gen T4Rs 8 09-19-2016 01:08 PM
Drive shaft/Prop shaft question (Picture Incl.) rinkman07 4th Gen T4Rs 4 03-31-2014 09:49 PM
thump ,clunk noise in my drive shaft. where is grease fitting for drive shaft? taeytaey 4th Gen T4Rs 2 09-12-2012 10:30 AM
