Old 07-24-2022, 03:49 PM #151
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Originally Posted by Bad Luck View Post
All of those codes list air/fuel sensor as a possible cause so I’m feeling pretty good about it. I’ll probably hook up my pirate techstream to it on Monday and look at the air/fuel sensor data. If nothing else I doubt it’s ever been replaced and might get a little better fuel economy after changing it like I did with my last 4Runner. I’ll let you know though.
Do you have a link for both? I just pulled a P0171 (in addition to the P0125) on the way home today which leads me to believe I'm having the same problem you are.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 07-24-2022, 05:14 PM #152
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
You have a 98 so my parts won’t work for you, but you can look it up on denso’s website. ERROR: The request could not be satisfied I’m not sure if denso makes a maf for you or not. The maf is more of a just because part to try for my coasting high idle.
Old 07-24-2022, 05:21 PM #153
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I think they were discontinued. The early years maf is quote costly oem.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 07-24-2022, 05:27 PM #154
Alright, I couldn't find one there so I'll just get one at O'Reillys with my friends discount, hopefully that's good enough to work
281k Miles
Build Thread
Old 07-24-2022, 05:35 PM #155
Thanks for the video. It confirms my suspicions, but I have no idea why it's idling high until my road speed drops. My stopped idle (cold and hot) is within spec so that tells me the IAC is good. MAF readings when coasting aren't out of the ordinary. Same with the throttle position. It's a mystery.
My 5sp Saturn drops to 900 and stays there until completely stopped. Then drops to 700rpm idle speed. I always thought not going all the way down may have something to do with maintaining a vacuum for the brakes……
Old 07-24-2022, 06:26 PM #156
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Until I can pull several from the pick and pulls clean them and test run them for a few weeks. That's your best bet. As be quite a while before I have a few oem used ones.
Old 07-24-2022, 07:19 PM #157
Sounds like a plan to me, once you've got one DM me and hopefully we can get something worked out! Thanks so much
281k Miles
Build Thread
Old 07-24-2022, 07:24 PM #158
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Need to find some clean and test them.. Then we see what we have available
Old 07-30-2022, 09:53 AM #159
Real Name: Patrick
Real Name: Patrick
7/30/2022 204747 miles
-Replaced air/fuel sensor (Denso 234-9003) $120
-Replaced MAF sensor (Denso 197-6020) $74
-Finally greased front and rear driveshafts (Lucas Red "N" Tacky #2) (McNaught k32 Grease Gun) $60
Replaced the air/fuel sensor for several DTC's I've been getting. Never did get a chance to drive around with my pirate techstream and watch data. Replaced the MAF sensor as well. Probably didn't need to. I'll keep the old MAF as a spare. Finally got around to greasing the front and rear driveshafts. Man was that messy. Mostly because I was trying to push out all the old grease that the manufacturer used. The greases are compatible, but it makes me feel better. Skid plates are still dripping oil at a slow, but steady pace. I think I have a leaking oil pan in addition to a leaking rear main seal. I'm not in a big hurry to address either of those. I have more pressing projects like my never ending kitchen remodel.
Old 08-19-2022, 02:41 PM #160
Real Name: Patrick
Real Name: Patrick
8/17/2022 205105 miles
-Replaced windshield through Safelite. Green with blue tint. $385
I had a couple rock chips and an abundance of little sand chips in the windshield. After seeing @Sarki replace his windshield I decided I deserved a new windshield lol I had Safelite come to me at work for the replacement. Of course the day that I scheduled decided to rain, but fortunately I was able to park in the shop in an empty bay for the guy to do the windshield replacement. There were a few rust spots under the windshield rubber molding, but he cleaned them up and put a rust converter then primer on the rust spots. Overall I'm very happy with the result. It's amazing driving with a brand new windshield! I ordered Cerakote Ceramics windshield treatment and trim treatment. They should be arriving today, but it's going to rain for the next week so I will have to wait to apply it. If you are on the fence about getting your windshield replaced DO IT! You won't regret it.
Old 08-19-2022, 03:46 PM #161
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Have any pics to show? I’d like to get a new windshield since mine has a couple minor rock cracks from lots of highway driving. And also minor little specks that just won’t go away. But I can’t drop $385 right now for it if I don’t NEED it and it’s not obstructing my view. I’m curious to see how the tint turned out, too.
Old 08-19-2022, 04:07 PM #162
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Try calling around to some local independent installers, I got mine done a year or so ago and it wasn’t even $200 and the guy does a really good job
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 08-19-2022, 08:30 PM #163
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
You should contact your insurance carrier. I have Hagerty Insurance and they confirmed a glass claim will not affect my premium at renewal time so I decided to go that route instead of paying out of pocket.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 08-19-2022, 08:33 PM #164
Prices have gone up in the last year or so as I replaced the windshield on my 2000 4Runner about a year ago at the same Safelite facility I had the windshield in my 02 replaced and only paid $220 at that time.
They claimed the increase was due to “supply chain issues”……very convenient!
2002 SR5 Sport 4WD
Old 08-19-2022, 09:54 PM #165
Real Name: Patrick
Real Name: Patrick
Mine was more expensive because I had them come to me ($50) and paid extra to be the first one that morning ($15). But I did get $50 off by starting to make an appointment but not finishing it. They emailed me a discount code the next day which obviously worked lol
4runner , case , transfer , transmission , work
Liquidmantis's modest [boring] build thread Liquidmantis 5th gen T4Rs 134 05-24-2023 10:17 AM
JR's basic boring "build" - dog hauler and ski transport 99blkx 3rd gen T4Rs 20 05-11-2021 11:41 AM
