Old 04-17-2022, 12:59 AM #1
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
How many miles until your original alternator and/or starter failed?
Saw this in the 4th gen section, seemed like a good idea
And what did you replace it with? New or rebuilt OEM, or some other brand?
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 04-17-2022, 07:25 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
My experience is the alt brushes will last 180k to 250k as an average. Most likely it depends on the environment and conditions it's in.
Best to always use remfg densos or rebuild them yourself.
For whatever the reason, the aftermarket mostly won't stay together and seem to fail very quickly.
The same issue seems to apply to the alternator as well.
Old 04-17-2022, 08:49 AM #3
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
My original starter failed at 208k miles. Replaced with remanufactured Denso. Replaced the starter relay as well. When it died I had to rush to disconnect the battery to prevent a fire! The starter continued to click even with no key in the ignition, and I disconnected the battery as it had just started smoking and smelling.
Original alternator, never rebuilt, so far 212k miles. Hopefully soon I will upgrade to the Vitara alternator, and keep/rebuild my original as a spare.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 04-17-2022, 09:04 AM #4
97 limited Alt 120k miles. Rectifier failed. While it was apart I put a new diode block and brushes.
96 SR5 Alt with 230k miles brushes. Replaced with OEM brushes that failed 60k later. They were worn to nubs.
97 SR5 came with a CarQuest reman. Milage on it unknown. Put it in the 97 Limited while I was chasing down a diode block. Eventually those brushes wore out and I replaced them with OEM.
So I did have one Alt with replacement brushes fail again. I’ll admit the commutator wasn’t the best looking.
Both the 97’s and the 96 starters had their brushed replaced.
The 97 SR5 had the starter fail right after I but the rebuilt engine in with 260k miles on it.
Old 04-17-2022, 10:36 AM #5
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Starter didn't start dying until around 290k - but when it finally started it went out in a hurry. Replaced it with one from DB Electrical and haven't had a single issue in the past 15k miles since
I'm 90% certain I'm still with my OEM alternator. PO was pretty good at listing the work he did to the vehicle, but made no mention of the alt being replaced and it still appears to be original. However 300k is a LOT for an alt and it's possible it was replaced ages ago with an OEM unit and he forgot
Old 04-17-2022, 11:29 AM #6
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
A high percentage of the time, an OEM starter and alternator can be brought back to life pretty easily and very affordably. Starter failures are quite often a result of worn out solenoid contacts and plunger. Alternators charging sub-par are quite often due to worn out brushes.
Here's two videos to save you some money by breathing new life into your high quality OEM Denso starter and alternator. In the starter video, I used OEM parts which are pretty pricey. We link a much more affordable kit in the video description.
Old 04-17-2022, 11:29 AM #7
RS Dude's Avatar
RS Dude RS Dude is offline
RS Dude is on a distinguished road
RS Dude's Avatar
My original alt lasted until about 320k miles. Replaced with low mileage oem from junkyard.
'96 T4R SR5 V6 Auto 2WD 329,000 miles
RS Dude is offline   Reply With QuoteReply With Quote
Old 04-17-2022, 11:34 AM #8
MountainBiker MountainBiker is offline
MountainBiker is on a distinguished road
Starter 2000 T4R 3.4L
Starter solenoid started acting up at 201k miles. I replaced the contacts per Timmy's video, thanks Tim!! I'm not the original owner, but the starter and contacts looked original.
Starter 2002 Taco 2.4L
Starter contacts failed at 232k for the first time (I'm the original owner). I found a very inexpensive reman Denso starter on RockAuto, so I installed that. ~13 months later (just out of warranty) the contacts were failing. When I opened up the reman starter, the contacts were quite worn, so i think RockAuto shipped the starter with old contacts! Replaced the contacts with OEM contacts and plunger (I should've done this with the original starter!)
Alternators on T4R and Taco are okay so far
T4R=223k, Taco=245k so I'll be replacing the alternator brushes on both of them prophylactically within a few months.
2000 Limited: Toytec Superflex, 255/85-16, Lil Skips gas tank skid, SaVage rear bumper and skids, BAMF Sliders
2006 SR5: FJC Coilovers +2", Toytec Superflex, 255/85-16
Sold: 2017 TRD OffRoad Prem (this rig was too nice for me!)
MountainBiker is offline   Reply With QuoteReply With Quote
Old 04-17-2022, 11:44 AM #9
Unner's Avatar
Unner Unner is offline
Unner is just really nice Unner is just really nice Unner is just really nice Unner is just really nice
Unner's Avatar
OEM starter failed around 135k according to the PO. They replaced with a cheap Chinese one that failed around 240k. It failed due to moisture getting in and corrosion. Not the normal copper contact wear. I put a denso unit in at that time.
The OEM alternator failed at 170k. I stupidly put an advance auto lifetime warranty one in and sent the denso in as a core. The "lifetime warranty" one failed at 206k. I put another "lifetime warranty" one in and it failed at 219k. At that point the manager at advance was nice enough to give me a credit for the lifetime one towards a denso one. The denso is still going strong at 291k now.
Moral of the story. Only put denso/Toyota parts in these rigs when it comes to starters and alternators. Better yet rebuild them yourself like Tim showed above. They're critical parts that fail fast when they do and will leave you stranded.
The cheap Chinese starter nearly left me stranded in death valley. I started noticing issues there with it not turning over the first time or two. Then once in Beatty, NV filling up with gas it refused to start. I finally got it to start and didn't shut it off but 3 more times for the rest of the trip home from DV to Alabama. Not the safest thing, but it got me home. The next morning it would not start at all. The starter had died completely...
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 300k+ Miles
1987 Toyota Supra N/A - Stock, 2nd Owner
Unner is offline   Reply With QuoteReply With Quote
Old 04-17-2022, 11:58 PM #10
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
[What I assume was the OEM] '97 alternator failed at about 192K miles. Voltage (as read from the Scanguage) started running high for a few weeks, which I liked. 14.1v warmed up, instead of 13.6v---nice for the AGM battery! Then one day, voltage plummeted to about 12.2 warmed up. Luckily I had bought a Denso replacement (80A version) about 1 or 2 years before, so that unit went in the next day.
pluton is offline   Reply With QuoteReply With Quote
Old 04-18-2022, 03:58 AM #11
I bought a new alternator from DB Electrical for my Saturn SL. Very happy with it. I’ve lost track when I purchased it but it has well over 50k miles on it.
If I ever upgrade to the CS144 Alt I was going to buy a new one from them.
Old 04-18-2022, 10:23 AM #12
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
Original alternator still going strong at 245K miles.
Original starter started getting a bit intermittent at roughly 190 - 200K miles. I replaced the solenoid contacts, put it back in and it's been fine since.
JohnMc is offline   Reply With QuoteReply With Quote
Old 04-18-2022, 12:20 PM #13
RS Dude's Avatar
RS Dude's Avatar
Forgot to mention, still on original starter with 332k miles as of this posting! Densos ROCK!
Old 04-18-2022, 03:02 PM #14
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Still original
My 01 still has original most everything including starter and alternator.
Its easier to say what has been replaced, the heater control valve, Twice!!
Oh and the fan clutch, once. That is it! (yes rear bearing are original tool)
I have had to replace starter contacts on my fatherinlaws 97 runner once, it had about 250K at that time.
Old 04-18-2022, 08:24 PM #15
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
I replaced starter contacts at 199K in 2013. Now 224k
Never replaced the alternator, and I believe it is original
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
brand , oem , pixel , rebuilt , replace
How many miles until your original alternator and/or starter failed? Seymore Butts 4th Gen T4Rs 48 06-12-2023 02:40 PM
Original alternator at 185k miles possible? nick168 4th Gen T4Rs 37 01-29-2021 10:50 AM
2005 V8, Starter failed 280,000 km? Also keeps rolling backwards in Park Bernardchan96 4th Gen T4Rs 6 03-21-2020 09:00 PM
Replace Complete Alternator for Failed Voltage Regulator? GreyhoundGuy 5th gen T4Rs 7 07-24-2019 12:24 AM
CL Find - 1995 Toyota 4 Runner SR5 32K Original Miles/Original Owner DCOURTS1984 For Sale: Vehicles 4 11-27-2014 01:52 AM
