06-27-2022, 06:58 AM
#47
Last night I found some data on the oversized oil filters that are commonly used for the 5VZ platform. Posting this here to save as a reference for anyone who may need it/be interested. It has certainly swayed my decision to use the Napa Gold 1516 anymore from here on out. Looks like I will be returning to the YZZD3's instead that I've used for literal years and calling it a day. Can't go wrong with OEM Toyota!
06-27-2022, 07:47 AM
#49
Originally Posted by brillo_76
According to this if I am reading it correctly, the wix suck. Toyota has no information and the middle one is the best?
That's what I'm taking away from it. I don't think it says the Toyota filters suck, it just doesn't have efficiency data available, although I'd love to know what the stats are for it. It does say that the Toyota filter has more square inches of filtering media, and synthetic media at that, which I like. But according to the post, the Purolator PureONE is the best. I've used Toyota D3 filters for years and plan to go back to them at my next oil change. Of course I just changed my oil at the beginning of this month using the Napa Gold 1516. It'll work in the meantime, I just like to over analyze this kind of stuff. I would consider trying to PureONE filter, but I know I'll sleep better at night using a Toyota one. I love how this stuff drives me crazy.
06-27-2022, 11:29 AM
#50
Real Name: C8H18 Mike
The YZZD3 is not specifically synthetic rated, but what do you guys think about this filter with synthetic?
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
06-27-2022, 11:39 AM
#51
that brass on black looks amazing, love your build
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
06-27-2022, 12:03 PM
#52
I never once have had a single issue or complaint with the D3's. Even Blackstone told me that my oil filter did a great job keeping insoluble material within spec when I sent them my first sample. That was with the D3. But what turns me off to the Napa Gold now is the much smaller area of the filtering media and the percentages of efficiency when filtering "x" micron particles when compared to the D3. So that's enough to make me wanna go back to Toyota filters. I've also exclusively used synthetic oil on my rig, except for the first oil change after I got it, which was well over 100K miles ago. So it's had a good diet over the years to say the least. But even then, no adverse affects running synthetic oil w/ the D3 filter.
06-28-2022, 07:46 AM
#53
I've been monitoring a slight oil seep over the last few weeks that seems to be making its way down to the bottom of my oil pan. At my last oil change on 6/1/22, I swapped out my OEM drain bolt for the Fumoto-F133. When I installed the Fumoto valve, I actually used an OEM drain plug gasket instead of the supplied fiber gasket that came with the Fumoto valve.
This oil "seep" has been surrounding my drain plug recently and I'm wondering if it has anything to do with the gasket I used or if it simply needs to be tightened. I kind of want to remove the Fumoto and reinstall the OEM drain plug, but I really like the idea of running the Fumoto. I'm not really sure which direction I want to take this. I could try tightening the Fumoto to see if that helps any, but I also don't want to overtighten it and possibly run the risk of stripping my drain pan, which has happened in the past many, many years ago.
So last night I crawled beneath my rig and did some much needed investigating. The only wet/oily spots I visually observed were on the driver side, directly beneath the oil filter, where some of the FIPG seemed to be protruding a bit from where the pan seals to the bottom of the engine. When I poked it, a little oil would come out, so I'm not quite sure if that's exactly where this seep is coming from, but there wasn't any wet/fresh oil dripping down the pan from that particular location. So I wiped everything down as best I could and called it a night. I'll post some pictures here for reference as I continue to monitor this.
In addition to checking the oil pan, I took a peek at the external oil cooler as well. And while it is definitely covered in 300,000 miles worth of gunk, I didn't see any active oil leaks coming from it. So I think it's safe to rule that out.
I could drain the oil, remove the Fumoto valve and reinstall the OEM plug tomorrow or the next day if I really felt compelled to. The thing is, the oil has less than 1K miles on it. Kind of wasteful, but I'm willing to pay the price if that means it will stop this slight oil seep. If anyone has some input they'd like to give, I am absolutely willing to listen, as I'd like to put this to a halt as soon as possible. In addition to all of this, I actually purchased some SuperTech full synthetic high mileage oil that I have every intention to use at my next oil change. I've only ever ran full synthetic, whether it was AMSOIL, Pennzoil Platinum, Pennzoil Ultra Platinum, and most recently, Kirkland Signature full synthetic. All in the 5W-30 flavor. I even emailed Blackstone Labs and asked about the benefits of running a high mileage motor oil. I'll post their response to my inquiry below:
"Joe,
Thanks for reaching out again, and thanks for the kind words!
We typically suggest using what the manufacturer recommends, but feel free to try other brands/grades/formulas. Switching between synthetic and conventional oil is okay too. I wouldn't expect changes in wear levels due to the oil type alone, but maybe you'll notice other changes on your end like quieter operation, for example.
Kirkland oil is a popular choice and it tends to do a good job like most oils we test, so I don't think it's a bad idea to keep using it. I would be surprised if it caused any trouble for your 4Runner's engine.
High mileage oil is advertised as helping to recondition seals and gaskets, and maybe there's some truth to that, but in testing, it doesn't look significantly different than other oils/formulas. The additive packages are often similar, but maybe there's something about HM oil that doesn't show up in testing. Feel free to try it to see if it helps with the seep - it shouldn't bother anything. If you don't like it for any reason, then you can always switch to another oil.
Let us know what you find with the seep when you send your next sample. If you find a bad seal/gasket and fix it, then we may find high silicon (from silicone sealers) in the next sample, which should wash out with each oil change thereafter.
Please let me know if you have any other questions.
Thank you."
06-28-2022, 03:43 PM
#54
Could be the oil filter itself leaking (well, the gasket).
One of the other nice things about the OEM filter is that they use a real o-ring instead of a cut square gasket. They are less likely to leak, even with lower installation torque... oh, and the gasket comes pre-lubed. I have moved back to the "D3" filter after years of using PureONE filters on multiple Toyotas. Just buy in bulk!
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-28-2022, 07:55 PM
#55
No visible oil leaks around the oil filter were observed. I’d like to rule it out as well. I’m beginning to wonder if maybe it’s the actual Fumoto valve itself that could be leaking, since I wasn’t able to use a torque wrench when installing it. I’m half tempted to ditch the thing altogether and just use my OEM drain plug.
Totally agreed about the OEM filters. They have excellent build quality, QC, are always pre-lubricated and even have that plastic wrapped around the bottom to prevent contaminants from entering into the filter itself. They do a great job, I’ve never once had a single issue with one and they’re so smooth when installing. I’m definitely switching back to them at my next oil change and look forward to it.
06-28-2022, 11:40 PM
#56
1996-2002 Factory Service Manual - Google Drive
1996-2002 FSM in Google Drive link for anyone who may be in search of it:
4Runner FSM 1996-2002.pdf - Google Drive
06-29-2022, 06:35 PM
#57
In light of my second to last post about chasing this potential oil seep, I went ahead and drained my oil today and then removed the Fumoto valve. Going to be returning it for a full refund. I really love the idea of having it and everything but not at the cost of potential oil leaks. It was also pretty neat to watch it drain when I opened the valve. It did take a bit longer than normal, but by no means did it take excruciatingly long.
So this morning I purchased a new OEM drain plug from Toyota and installed that. Additionally, I was reading the 96-02 FSM and discovered that the engine oil drain plug factory torque spec is 29 ft-lbs. I've always referenced my Haynes manual over the years which specified 20 ft-lbs. I decided to set it to halfway and torqued the new drain plug to 25 ft-lbs, seemed nice and tight. Installed with a new OEM gasket as well.
Finally, I figured that if any time would be good to perform an experiment, it would be now. I purchased some SuperTech Full Synthetic High Mileage 5W-30 and poured that in. Coupled with a YZZD3 filter, I'm hoping for good results. I know that I had recently switched to Costco's Kirkland Signature Full Synthetic, and it's a fine oil, but I'm going to exclusively run this high mileage stuff for a while and then send off a sample to Blackstone to see what exactly they say. As I'm approaching 315K I think using a high mileage motor oil may be a good thing, but only time will tell, so we'll see.
Debated on bringing my oil change interval down from 5K to 4K, but I think I may just leave that alone and stick to 5K. I haven't had any issues with a 5K interval, but sometimes I get overprotective about things and want to reassure myself that my engine is happy and healthy. I'm determined to get my rig to 400K and hopefully beyond. Pics for reference down below.
Date: 6/29/22
Mileage: 314,863
06-29-2022, 06:50 PM
#58
Much ado about nothing, but whatever makes you sleep better at night
06-30-2022, 01:18 PM
#59
I still don't see how a (theoretical) leak at the drain plug made it up to the lip of the oil pan...
Save that Fumoto valve until you know your leak is fixed.
06-30-2022, 01:28 PM
#60
It couldn’t, so I’m assuming that there are two different issues here. The first being the FIPG that’s protruding from the pan that seeps oil when I poke it, the other being whatever is coming out at and staying near and around the drain plug.
I returned the Fumoto valve this morning for a full refund. Not worth it to me and I have much better peace of mind with the OEM plug. I can say that I’ve tried one now and didn’t like it, which is okay. I’ll continue monitoring the new drain plug to see if anything else happens. I’m hopeful that this will resolve the issue with the drain plug. The fipg that seeps when I poke it isn’t leaking onto the oil pan itself, which is good. And who knows, maybe it’s just oil that has fallen onto it from when I’ve removed the oil filter in changes past. I cleaned everything up nicely yesterday so we’ll see what happens from here on out.
