Old 06-09-2022, 10:18 AM #31
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Originally Posted by Brian. View Post
Are you going to monitor State of Charge (SoC) in any way, or just wing it? It can be as simple as a voltmeter (though that works WAY better with a LiFePo4) or as complex as a meter that actually measures power use with a shunt:
M2 DC Multimeter with SoC - Blue Sea Systems
This was one area where going cheap was a complete failure. Mine is never accurate in regards to actual SoC, so I just watch the volts and know to charge if it drops below 13.0 (about 30% SoC for LiFePo4). There are other brands than Bluesea, so if that's the route you take, shop around.
Redarc has a dual volt gauge, but I was looking at this Ironman gauge
12V Dual Battery Monitor Display
Neither do SoC, specifically
On the better-than-nothing side, there are plenty of these out there
Digital Voltmeter Rocker Style Dual Voltage Monitor
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 06-09-2022, 10:34 AM #32
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
https://a.co/d/7kYMT0c
Whew, that's an expensive voltmeter (ironman). I think I'd go cheap if just watching volts, not exactly a complex thing to measure. That was the main reason I went cheap with my SoC display ($20 irrc, like this Amazon.com: bayite DC 6.5-100V 0-100A LCD Display Digital Current Voltage Power Energy Meter Multimeter Ammeter Voltmeter with 100A Current Shunt : Automotive ), I knew it'd work fine as a voltmeter too.
If you've got the money/desire, you could always do 2 of these: (edit, one will do 2 batteries apparently... new product to me, oops one is voltage only)
Amazon.com: Victron Energy SmartShunt 500 amp Battery Monitor (Bluetooth) : Automotive
and monitor on a phone/tablet.
2nd edit: Checked the reviews and was pointed here, this looks even better... almost tempting me to reconfigure my setup (can do 2 batteries, has onboard logging, etc...):
PowerMon - Bluetooth LE Advanced Battery Monitor / DC Power Meter with– Thornwave Labs
Brian. is offline   Reply With QuoteReply With Quote
Old 06-09-2022, 12:00 PM #33
Not looking to put more on my phone, I'd prefer something on the rig - space is a concern and a cheapo voltmeter is better than nothing
I like this Renogy 500A Battery Monitor, High and Low Voltage Programmable Alarm, https://a.co/d/hOQKp33, just wish it were dual battery capable
There are also plenty of cheapo volt/capacity meters out there in the $20-50 price range. For example
Battery Monitor, DROK 10-100V Digital Battery Capacity Tester, Percentage Level Voltage Temperature Switch Meter Gauge 12V 24V 36V 48V LCD Display Marine RV Battery Power Indicator Panel https://a.co/d/i80v1q0
Sent from my Pixel 4 XL using Tapatalk
Old 06-19-2022, 01:55 PM #34
Looking at shunt based voltage meter gauges to monitor both batteries (state of charge, current draw, voltage, etc) and am leaning towards this 350A round gauge
[URL unfurl="true"]https://a.co/d/1Z0tHpz[/URL]
It is 2 1/16" and will fit in an A pillar gauge mount, either in an AutoMeter aingle
[URL unfurl="true"]https://www.autometer.com/2-1-16-toyota-tacoma-95-98-4-runner-96-98-single-pod.html?gclid=Cj0KCQjwkruVBhCHARIsACVIiOxZwiv_x9-qvQjobt0EOkiNx9YnLL9y8etBH8279lUTmPcJsB8IISAaAlnhE ALw_wcB&gclsrc=aw.ds[/URL]
This one is black and will need to be painted to match the interior
Or a Lotek dual gauge pod already oak colored to match my interior, but requires removing the a pillar grab handle
[URL unfurl="true"]http://www.gaugepods.com/toyota.html[/URL]
Read a bunch of threads so far about the A pillar gauge pods, always looking for more real world feedback, like does it obstruct visibility while street driving?
Old 06-19-2022, 02:51 PM #35
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am surprised none of the forum members vendors make a A pillar cover to hold several gauages.
Should be able to 3d print those now and even match the few interior colors close enough that they look factory.
agm , battery , charging , deka , isolator
My 2014 4Runner isn't charging the battery? Theomoji General Discussions 6 04-16-2022 11:56 AM
88 4runner charging issue maxmad88 Classic T4Rs 1 06-15-2021 01:17 AM
Rear Storage Drawer Project: 4th Gen 4Runner Pritchnakoff 4th Gen T4Rs 19 02-15-2016 12:59 PM
88 4Runner charging issue Jordan Petry Classic T4Rs 4 08-12-2014 01:09 AM
86 4runner charging Curmudgeon Classic T4Rs 7 09-28-2012 04:22 PM
