Old 07-29-2022, 11:46 PM #1
Jancamp04 Jancamp04 is offline
Jancamp04 is on a distinguished road
Help with hot temperature gauge.
Hi! This is my 1st post! My 1999 4Runner has 388,000 miles! Beautiful vehicle I inherited from my brother in law when he passed from cancer. Gonna take it to a million miles, which was his dream.
Has new radiator, water pump, timing belt, and thermostat and complete flush. Mechanic's cannot find why the temp gauge still continues to go to hot, even though no steam or other signs of overheating. Also combustion test shows no head gasket issues. Gauge goes down when heater is turned on.
At times it drives perfectly for 50 miles or so, over hills and curves. Next time it shows hot. I'm sooooo frustrated. Any suggestions would be greatly appreciated. My 4Runner is my baby. 1999 Limited, 2 wheel drive, Fla Georgia truck.....no rust.
Jancamp04 is offline   Reply With QuoteReply With Quote
Old 07-30-2022, 12:08 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Could be a lot of different things. Bad fan clutch, bad radiator cap, air pockets in the cooling system, bad mechanics, blocked condenser, etc.
Can you isolate when it gets hot? Does it happen in stop and go traffic or cruising highway speeds? Only with the ac on?
Old 07-30-2022, 12:45 AM #3
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
Did the mechanic use a toyota oem thermostat also an Aisin WP or oem. The jiggle valve on the thermostat should be at 6 o'clock most mechanics not fimiliar with 3rd gens put that at 12. If the system was burped properly then double check that the hoses are not collapsing. Even though you have a new radiator the symptoms point to restriction in the cooling system or exhaust system. Also the radiator cap. If overheating just at idle then it could also be the fan clutch.
Old 07-30-2022, 02:02 AM #4
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Google 'burping the coolant system'. Chances are you've got air trapped and it needs more coolant to top it off. All else fails you replace the Engine Temperature Sender - the little one prong sensor on the water bypass way in the back of the engine.
326WHP 347TQ
Old 07-30-2022, 04:01 AM #5
19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold
When you remove the radiator cap is coolant touching the bottom of the cap?
With those miles the fan clutch needs replaced.
Old 07-30-2022, 10:19 AM #6
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
What motor?
When you say hot what does the temp gauge indicate?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
4runner , gauge , hot , miles , shows
outside temperature gauge... Toowiley 3rd gen T4Rs 3 10-13-2013 09:49 PM
2005 4x2 sr5 4.0 temperature gauge/fuel gauge Josh05 4th Gen T4Rs 0 09-10-2013 04:39 AM
Temperature gauge help!!! bertsch911 Classic T4Rs 8 02-28-2013 01:06 PM
temperature gauge? bigtino Problems & Warranty Issues 0 01-10-2007 10:04 PM
Outside Temperature Gauge JP4RNR 4th Gen T4Rs 6 09-26-2006 03:07 PM
