Old 10-17-2022, 04:03 PM #1
ch1966 ch1966 is offline
ch1966 will become famous soon enough
CS144 swap - High Voltage?
My 4runner started an intermittent "Battery" light last week.
I got my parts together and swapped to the CS144.
Now I'm getting 14.4 - 14.5 volts.
How long until I fry everything?
Willie was a big help:
ch1966 is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 04:22 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
How long has it ran with the higher voltage? Maybe your battery is low and its just charging it as 14.4 to 14.5 isn't supper high. Fully charged should be around 13.8volts.
Old 10-17-2022, 04:43 PM #3
The batt light had been intermittent. It was running 13-14 V with the old alt.
Do you think the computer will iron this out by itself? I've only had one test drive since install. Of course the battery was disconnected in the process.
Old 10-17-2022, 05:28 PM #4
14.5V won't fry anything in the truck. Automotive electronics are usually rated to 16V and sometimes higher. American manufacturers often have higher charging voltages than Japanese manufacturers - at least with old 'dumb' alternators like the CS1xx alternators.
Also, charging voltages are higher in colder weather (even the OEM Denso will supply up to 14.8V when very cold - all the way down to 13.6 or lower in very hot weather).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-17-2022, 06:11 PM #5
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
How cold was it when you started it and it made 14.7v? How long did you run it before shutting it off? 14.7v might be normal if it's 45ºF out and you only ran it for 10 minutes. I know that AGM batteries can accept 14.7V when it's cold without damage, don't know about flooded lead acid (FLA).
For the last few months, my stock 80A alt (with added voltage boosting diode/resistor thingy)has been giving 14.7V when first started and for the first 5 or 10 minutes of running without damaging the vehicle electrics.
pluton is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 06:42 PM #6
Very mild out today. low 60s.
I just made a good run with it.
14.4-14.5V
Thats with my OBD reading and it matches my Fluke.
When I first started up to leave, it spiked to 14.8V a split second then settled down to 14.4-14.5.
I turned on my brights and it dropped to 13.8 for a split second, then back to 14.4-14.5V.
ACDelco Gold 335-1050 Made in Mexico. $103 on Amazon right now.
If anyone is doing this, and you need to get your spacer washers on your top bolt, I discovered that you can use your adjustment bolts, a washer, and a crescent wrench to move that bushing on the top hole, giving you the room you need to get it all in.
Just have your crescent adjusted larger than the bushing but smaller than the washer and crank the nut.
Old 10-17-2022, 07:12 PM #7
Your voltage it totally normal for that CS series Alt. I prefer that voltage over Denso’s VR settings.
Enjoy a higher state of charge with your upgrade.
Old 10-17-2022, 08:07 PM #8
Joshv4runner's Avatar
Joshv4runner Joshv4runner is offline
Joshv4runner is on a distinguished road
14.4-14.5V
What size washers did you use as spacers?
looks good
00' 4Runner Limited- Auto trans, E-locker, grey-wire mod, custom rock sliders, B&M 70268, TRD exhaust tip, 285/75/16 Duratracs
R.I.P 99' 4runna- auto trans, 4wd, tacoma whip mod,B&M 70768 tranny cooler, 265/75/16 Cooper Discoverer at3
Joshv4runner is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 08:40 PM #9
looks good
Thanks.
Not sure on the size 7/16 or 1/2"?
There was a dozen or so of them laying in a parking space. I've had them rattling around in my cup holder for a couple months now.
cs144 , fry , long , swapped , volts
P0113 - MAF high voltage? 4OYOTER 4th Gen T4Rs 4 09-02-2022 05:24 PM
High idle after miniheader swap 3rz Pyral 3rd gen T4Rs 5 11-12-2021 09:40 PM
CS144 Alternator Running High Voltage Toy2play 3rd gen T4Rs 11 06-29-2019 03:40 PM
Alternator Voltage is too High -- Battery Light Flickers 98Base4R 3rd gen T4Rs 11 09-10-2018 09:17 AM
High Amp Alternator swap for 3rd Gen octanejunkie 3rd gen T4Rs 0 01-25-2017 01:37 AM
