Old 02-18-2023, 08:11 AM #16
The parasitic draw comes from the wire harness relay socket being pinned incorrectly. It put a permanent .5a draw on the battery. Swapping the two red wires fixes it.
Old 02-18-2023, 10:27 AM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Thank you. I thought I remembered some of those could have been wired wrong...
Old 02-20-2023, 04:54 PM #18
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
While on the subject, after searching pretty high and pretty low, I'm surprised I can't find an adapter to connect dissimilar spades so I can connect the Baja Designs (small female ends) to the Camry switch spades (larger) without crimping a few connectors and wires together. Not a big deal to do, but it would be a lot easier if there was a small male to large female spade adapter. Is this to discourage connecting different gauge wires, or am I missing some other solution? - Electrical Dummy
Rocker or push switches that fit dash knockouts?-spades-jpg  Rocker or push switches that fit dash knockouts?-switch-jpg
Old 02-20-2023, 08:39 PM #19
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Can always file it down. I wouldn't use adapters on some stuff (if they existed) because it's another point of failure, which is unacceptable for kill switches.
All my projects use the larger shovel connectors to keep things standard, so I've never had that issue.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 02-21-2023, 01:09 PM #20
Real Name: Blair
Real Name: Blair
Agreed - my fuel pump killswitch is super heavy duty water-resistant rubberized metal toggle with screw-together connectors. Weird that Baja used these small connectors. I think I have sheet metal snips that will do the bulk of the work and file the rest.
Old 02-22-2023, 08:06 PM #21
zback zback is offline
zback is on a distinguished road
Easy, get the Oznium Scion OEM style rocker switch. I use 2 of them on my 4runnerm one with the green LED and one that doesn't have an LED. They fit into the blanks and look stock.
You can see the one without an LED in this photo that I took for an unrelated project.
I don't have any good photos of the one that I have fitted with an LED, but the listing I posted is accurate. I use it for my fog lights, no complaints. By 3 lead you mean it has 3 shovel connectors on the back (one for the LED ground)? The LED version is that.
I'd like to know more about how you did the thermometer add on!
zback is offline   Reply With QuoteReply With Quote
Old 02-22-2023, 10:25 PM #22
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
You can read my writeup on it here
Old 02-23-2023, 04:12 PM #23
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
I prefer the look of push button switches over rocker switches (it seems more OEM looking in our trucks), so I repurposed a junkyard seat heater switch from an '01 Limited for my DRL lights switch (I wanted manual control of the lights).
It was a ton of work, a true labor of love, especially to transfer the "headlight" symbol from a cheap Chinese switch, but it looks and works great, is backlit, and the light on top comes on when the DRL lights are on.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 02-24-2023, 05:22 PM #24
Real Name: Blair
Real Name: Blair
Nice work. I need to interrupt my DRL with a switch one of these days. It's not stealth at all.....
Edit - didn't realize that on a 2000 you can just disconnect the plug near the battery - sweet. I'll attach it when I need to be a good citizen but not off road.
Old 02-24-2023, 10:12 PM #25
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Like Hyundai/Kia with immobilizers, only the Canadian version got them to satisfy a law. DRL are absent on US 4runners iirc.
Old 02-24-2023, 10:18 PM #26
Real Name: Blair
Real Name: Blair
Nope - we got em, too. I have a CA rig that's always lit. Not for long!
Old 02-24-2023, 10:45 PM #27
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Depends on the year. Started being optional in 99, but was standard on all trims starting in 2001.
dash , found , rocker , super , switches
ABS toggle switches 5VZ-FE 3rd gen T4Rs 6 06-07-2021 07:57 AM
OEM rocker switches- where to find HappyHooligan 3rd gen T4Rs 1 08-24-2020 10:35 PM
Rocker switches 541joseph Classic T4Rs 7 01-12-2014 10:43 PM
Contura II Rocker Switches? 4ever4running 3rd gen T4Rs 42 07-15-2013 10:46 AM
Rocker Switches BigRogers 3rd gen T4Rs 6 10-29-2011 11:07 AM
