Originally Posted by Bad Luck
The clock spring contains several different circuits so it’s likely that the horn and cruise control circuits in the clock spring are worn and not making good contact. My vote is on the clock spring. Even more likely to be the clock spring if your airbag went off during your accident.
Edit: the horn grounds to the body where it bolts to the body.
I did replace the clock spring after the accident, so I'm not sure if that'd be the cause, however I think I'll just order one once I find one.
I do know the horns ground to the body, but I was thinking maybe the problem was grounding the clockspring
If it's not the clockspring, I can at least sell it to my friend who ironically has a really similar problem to me.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
