Pilot Bearing Removal
mtbtim
Dudes, if you have a manual transmission, you'll eventually be facing a clutch job. As part of a clutch replacement, the pilot bearing in the end of the crankshaft should be replaced. A simple and very effective technique to remove a pilot bearing is by using some bread, a bolt and a hammer.
Check out the video and see how it's done. Hope you Dudes like it. Happy Wrenching and Sic Mods for All!
<iframe width="560" height="315" src="https://www.youtube.com/embed/Z4qQ2DoM3VM" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Some people say to use grease, but it's way easier to clean up wet bread mush than grease.
And yeah, it does work ridiculously well.
I used grease, but had an issue with the grease pushing through the gaps in the bearing rather than pushing the bearing out.
I've never pulled an automatic transmission out of a 3rd gen, but I didn't think they had a pilot bearing (or similar). That looks like a flexplate not a flywheel so was this for demonstration purposes or do automatics have a pilot bearing for some reason?
It was for demonstration purposes. The engine we had suspended is a 3.0 V6 from a 2nd Gen 4runner that had a manual transmission. We're putting the engine into a pickup that also had the 3.0 engine but with an automatic transmission. Automatics don't use a pilot bearing. The shaft of the torque converter fits into the end of the crankshaft so you can't have a pilot bearing there occupying that space.
Thanks for clarifying that! I was really questioning my sanity for a minute there lol I thought that was the case with the torque converter and crankshaft mating, but wanted to be sure.
