Old 05-27-2023, 06:40 PM #1
Madarasskishbosh Madarasskishbosh is offline
Madarasskishbosh is on a distinguished road
Disabling Alarm
Hey Y’all,
I have a 2001 Limited. My key fob has started dying. The unlock button works great, but the lock button doesn’t at all or does after like 5 clicks. If I lock the doors using the manual locks I am not able to unlock it with the fob. And when I use the key to u lock the doors the alarm goes off. So basically I can only use the buttons on the fob to get in and out of my vehicle which seems pretty dumb to me. So, now that my fob is dying I wish I can open my vehicle and lock it using the keys without the alarm going off. Is there any way to disable the factory alarm to allow me to use my key?
Thanks in advance.
Madarasskishbosh is offline   Reply With QuoteReply With Quote
Old 05-27-2023, 06:50 PM #2
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Should be pretty straightforward, I can't remember exactly where the RS3200 is located for you, for my 98 it's located under the drivers seat, just unplug that and that should be all you need
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 05-28-2023, 09:47 AM #3
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
If it is the factory immobilizer you cannot disable the alarm. Try replacing the FOB battery with a quality battery and cleaning the connects in the FOB.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 05-28-2023, 09:52 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yup. I unplugged one of mine. the truck wouldn't start. You have to remove the wiring harness completely to correct the issue.
alarm , fob , key , lock , vehicle
Alarm Feed Back: Viper 5305V (Alarm/Remote Starter) + Smart Start markie671 5th gen T4Rs 2 07-06-2017 10:56 AM
Avital 5303L Alarm install issue with Remote start triggering alarm. SJC4Runner 4th Gen T4Rs 14 05-21-2017 02:36 AM
Disabling Factory Alarm Weave 4th Gen T4Rs 1 01-17-2017 07:23 PM
3 remotes needed? Remote starter, alarm, notify me if alarm activated, & back window Woodsie8 3rd gen T4Rs 5 12-12-2012 07:22 PM
3 remotes needed? Remote starter, alarm, notify me if alarm activated, & back window Woodsie8 General Discussions 2 02-03-2012 07:22 PM
