09-20-2023, 11:34 PM
#1
Junior Member
Junior Member
P0420 code? READ THIS BEFORE REPLACING CATALYTIC CONVERTER!
Long story short/long…
For the past several months I have been trying to diagnose and repair what had been told to me was “99% of the time” a bad catalytic converter on my 2002 SR5 Sport.
A few years back, the car Failed California smog test. Mechanic immediately said replace the cat, you’ve got 200k on the car, it’s time. I waited and took… alternate routes to getting the car roadworthy. Alternate and pricey. This year I decided to actually fix the issue, knowing a new cat would run me thousands of dollars.
I started as small as I could. Cataclean. It appeared to do nothing. I bought the denso O2 and fuel air sensor and had a mechanic install them. More cataclean. List of laborious drive cycles. Check engine light kept coming on after reset, so I knew the sensors were ok and I just spent $275 on nothing.
An interesting thing happened at this point:
CEL on
P0420 code
P1130 code (new!)
P0171 code (new!)
It looked like my brand new denso O2 sensor had gone kaput in under 3 weeks! Not bloody likely but what can you do?
So I take it to a new mechanic. Friend of a friend. He says he needs to start all over from the beginning with a diagnostic. Which reveals a bad mass airflow sensor. He orders one and replaces it and tells me to drive around and see what happens. Meanwhile I am thinking GREAT I’m going to waste another tank of $6/gallon gas completing this insane drive cycle and the CEL is going to come back on and I’m still going to need a new cat.
But a miracle happens. I drive only about 30 miles at 55mph and the cat reads AVAILABLE/COMPLETE for the first time in years. I literally do t believe my eyes as I call the mechanic and he says bring it in I’ll smog it. I bring it right in, and pass smog.
Take from this what you will. Just one anecdote. But EVERYONE (including me after reading countless posts on here) was sure it was the cat, and it would have been upwards of $3k to replace. And finally $200 and a knowledgeable, legit mechanic later, everything is great.
Thank you to all who continue to share your info here. You know a lot more than me.
09-21-2023, 01:23 AM
#2
Elite Member
Real Name: Tim
Elite Member
Real Name: Tim
CEL on
P0420 code
P1130 code (new!)
P0171 code (new!)
But the key to this story is you actually got 2 other CELs other than the P0420 code to narrow the focus to the MAF. A lot of us, including myself have struggled with the P0420 code, and that's the only code we ever get.
But, you got me thinking now. I'm going to do a diagnostic on my MAF to see what result I get.
__________________
"My old man is a television repairman, he's got this ultimate set of tools. I can fix it!"
09-21-2023, 04:44 AM
#3
Junior Member
Junior Member
Yeah the weird things:
- I drove the car for years after failed smog test and CEL never came on.
CEL only came on after very first mechanic cleared codes and I did the whole drive cycle- which tells me the cycle is truly insane if years of daily driving can’t pop it.
After new denso sensors were installed, drive cycle again, and p0420 came up alone.
Drove it again for 2-3 weeks before taking it to the last mechanic, who suddenly informed me of the other 2 codes comibg up for the first time. Then he replaced the MAF sensor and all codes disappeared and CEL never came on again after he cleared it following install. All it took was a few miles of regular driving, as he predicted, and the cat was ready, passed smog. He also mentioned the bad MAF was causing the engine to run too LEAN, way too lean.
09-21-2023, 11:11 AM
#4
Elite Member
Real Name: Tim
Elite Member
Real Name: Tim
I've gotten the P0171 (too lean) code a few times as well, but a cleaning of the MAF always remedied the issue. Like
@ gamefreakgc
mentioned, if your MAF was actually malfunctioning years ago, why didn't the ECU trigger the other codes long ago? That's the question I have.
Anyway, I'm going to open my FSM and look at the specs to test my MAF to see if it is within spec.
Update: I did an ohms resistance test of my MAF and it seemed it was in spec. There are 3 temperature ranges the FSM gives values for and my MAF (using an infrared temp gauge) was a little above the lowest temperature they provides ohms resistance values for and it was in the ballpark. I did have a spare MAF and it also looks like it's within spec. I swapped in the spare and I'm going to see where it gets me. 2 years ago when I was up for a smog check, I struggled to get the catalyst monitor showing complete without popping a P0420 code. After using several rounds of Cataclean and swapping out my upstream air/fuel sensor and downstream O2 sensor, I finally got the system showing ready and I was able to get my rig to pass the smog test so I could get my new registration tags. Fast forward to the present, and I'm dealing with the same issue again. My rig wasn't popping the P0420 code for a long time, but it started acting up again a few months ago, conveniently timed with my need to get another smog check in the People's Republic of California. I'll report back if the MAF swap had a positive effect.
__________________
09-21-2023, 11:25 AM
#5
Elite Member
Real Name: Jerod
Elite Member
Real Name: Jerod
Quote:
@ gamefreakgc
My intuition is that it will test out fine. I've only had one MAF show bad resistance readings on all the 4Runners I've worked on over the years and that was only after I stupidly knocked it off a high shelf and cracked open after hitting the concrete floor. The other clue was that the 4Runner wouldn't start ha!
09-21-2023, 11:36 AM
#6
Senior Member
Senior Member
I get a random P0420 when running in 4Lo for extending periods. I clear it, and it doesn't come back. It's done it only twice, and it's been over a year since it happened. Definitly an odd case for me.
I'm gonna try cleaning my MAF anyway and see what happens.
__________________
The 4Runner Show
09-21-2023, 10:05 AM
#8
Senior Member
Senior Member
I got some money off my '99 when I bought it because the CEl popped on. The motor also ran oddly, a bit of a lean stumble when the throttle was opened, and a sort of hanging high RPM on shifts (manual trans). Long story short - they'd overoiled a K&N air filter, which got oil on the MAF wire, which is hot. This burned the oil and gave it an insulating layer of soot, which slowed down it's reactions to changes in air flow. So lean conditions for a little bit when the pedal went down, rich when the pedal came up.
OBD2 does what it can to state the symptom, but it can't guess what the root cause is. All it can say is what it sees - the the O2 sensor has some funny readings. It could be any number of things upstream f the exhaust.
__________________
'99 Highlander 5-spd manual e-locker no-running-board
SS 3" suspension lift/1" body lift/33" tires/'Snowflake' TRD Taco wheels/231mm Tundra brakes/bumpers/armor/sliders/winch/Sherpa Matterhorn rack
Manual front hubs, NWF Eco-crawler transfer case doubler, second gas tank
09-21-2023, 10:20 AM
#9
Member
Member
Well, at least your government compliant now, wouldn't want to be non-compliant. Smog tests are just a way for the government to get more of your hard-earned money. We all know CO2 is plant food.
Glad you're not seeing that CEL.
__________________
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
09-21-2023, 10:52 AM
#10
Elite Member
Real Name: Jerod
Elite Member
Real Name: Jerod
Interesting that the bad MAF didn't trigger the P0171 code sooner but it does have a very high tolerance, I think it's -/+ 39% and at 40% it throws the code. At least that's what mine did once in a failed tuning session where I had it pig rich and finally threw a code. A lot of the threads about it have aged and been lost to the bowels of this forum but we used to post regular reminders to clean the MAF sensor. It can cause a plethora of check engine lights like you've described, although I will also say that it's the first time I have heard of it causing a P0420 but it could make sense if the MAF was adjusting fuel beyond the O2 sensor's ability to adjust it back.
09-23-2023, 08:00 PM
#11
Elite Member
Elite Member
Quote:
I got a a P0420 due to a dirty MAF. Had some know it all on here claim the MAF never causes a P0420. I gave the MAF a good cleaning and...poof: no code. It just took a cleaning. Have you ever cleaned yours?
__________________
'99 4Runner SR5 5spd 3.4L V6 4WD(U.S), original '99 Talls in front, OME 906s in back, Hella fogs, Trekmaster shocks in front, Billy in back, no running boards, FIAMM horns, Alpine sound, Michelin LTX M/S2's, owned since new.
'97 HiLux SW4 5spd 4WD(Japan model bought in Brazil assembled in Argentina, very close to a 3.0 4Runner/Surf)
'71 FordWillys Jeep CJ5 (with straight six Ford Maverick 3.0 liter engine--lives in the mountains north of Sao Paulo Brazil)
My Backyard Frame Swap
04-12-2024, 09:10 AM
#12
Junior Member
Junior Member
Sometimes, what seems like a major problem turns out to have a simpler solution. Your experience highlights the importance of finding a knowledgeable and trustworthy mechanic who can accurately diagnose the root cause of the issue.
When dealing with trouble codes like P0420, it's crucial to consider all possibilities before jumping to conclusions about expensive repairs like replacing the catalytic converter. If you're ever in doubt about trouble codes or car repairs, it's worth seeking advice from professionals or using tools like Trouble Scan to get accurate insights into your car's health.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
