Old 10-18-2023, 11:49 PM #1
TheExplorer's Avatar
TheExplorer TheExplorer is offline
TheExplorer is on a distinguished road
light bar wiring issue with high beams
HI All, I am hoping someone can point me in the right direction with an issue I am having. 2002 4runner with DLRs.
I wired up a small light bar and tapped into the high beams for switch power (passenger side). When the vehicle is off everything works fine, the light bar comes on with the high beams properly.
When I turn the truck on, with the lights off, the relay is clicking away trying to trigger.
I tested the voltage and I have 3 volts going through the high beam wiring when the truck is running but the lights are off. When I turn the regular lights on, I only have .86 volts and the relay is no longer trying to switch on.
Could I have a short somewhere that I am not aware of?
Voltage readings
Engine off high beam wire -- lights off .78v, high beam lights on 12+v
Engine on high beam wire -- lights off 3v, reg lights on .86v, hi beams lights on 14+v
Thanks
Get out and explore the outdoors as much as possible
TheExplorer is offline   Reply With QuoteReply With Quote
Old 10-19-2023, 01:04 AM #2
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Voltage readings
Thanks
I would suggest into looking into an OEM foglight headlight stalk, I believe you'd need one from a 00-02, that way you can have it run separately as it's own toggle switch.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 10-19-2023, 11:56 AM #3
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
my light bar ( called moose lights up here) is wired to the battery. The toggle switch is powered from my cigarette lighter wire that runs the relay. Thus it has no effect on headlight wires. So ignition off, light bar off.
I have also read of others who will use a fog light stalk to power thier light bars etc. But I have fog lights
Old 10-19-2023, 01:08 PM #4
I can do this however I was hoping to control the light with my high beams, one switch instead of two. I had put one on my wife's car as she does a lot of night driving on dark roads and it works perfectly fine tapped into the high beams. Not sure what my issue is with the 3 volts when I start the truck.
Old 10-19-2023, 02:58 PM #5
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
It's the DRL system. Bumped into this adding a relay and wiring for double
wattage halogen headlight bulbs. I pulled the handbrake a click or two to light
up the brake warning light in the instrument cluster- that disables the DRLs.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
bar , beam , beams , high , lights
994R Wiring Lightbar to turn on w/ factory switch & high beams? hawkcharmer 3rd gen T4Rs 0 02-28-2023 06:16 PM
light bar spliced into high beams questions.. mr.walleye 5th gen T4Rs 8 05-04-2019 09:44 PM
Wiring diagram - trigger high beams Doc_Fry 5th gen T4Rs 3 11-22-2018 09:43 AM
Should the DRL light intensity of LEDs be the same as high beams? transistor 5th gen T4Rs 20 02-16-2018 08:30 PM
