Old 12-21-2023, 11:53 PM #1
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Rear brake line replacement
Can you get to the rear flex brake line fittings without dropping the rear axle? I saw a couple videos where they dropped the axle to get to the fittings but that seems like a lot of work. I think Phorunner did it by just removing the spare but I know his rig is lifted and mine is stock.
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 12-22-2023, 01:24 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I changed the rear flex line without dropping the rear axle. Granted most of mine only have one rear rubber line. [1996 - 2000] the 2001 and 2002 have 2 rear flex lines. I have to look but I would imagine you can change those 2 lines as well.
Old 12-22-2023, 08:59 AM #3
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Jack vehicle up so rear suspension is extended gives you more room. Hitch is good jack point.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
Old 12-22-2023, 11:15 PM #4
maxthebird maxthebird is offline
maxthebird is on a distinguished road
You can change the brake line just as Phorunner did. I followed his video and mine is not lifted. It's a little tight in there but very doable. No need to mess with the rear end.
maxthebird is offline   Reply With QuoteReply With Quote
Old 12-23-2023, 05:47 PM #5
Thanks guys. I did it just like phorunner without jacking up the rear end and it went fine. It was a little cramped but nothing terrible. The worst part was trying to bleed the brakes with one of those little hand vacuum bleeders. It just kept pulling bubbles despite trying grease around the threads, teflon tape, and a zip tie around the hose. Eventually just had my wife come out and pump the brakes while I used the old bottle bleeder method. That took no time at all.
Old 12-23-2023, 06:39 PM #6
Anyone else install the Stoptech braided line on the rear? The fittings were slightly different than the stock line. The fitting on the axle was a 14 mm instead of the stock 17 mm and the top line required that I hold the back of the fitting with a 17mm wrench while I tightened the 10 mm line fitting. Not a big deal but just thought it was strange since the front lines fit up just like the stock lines.
axle , brake , fittings , line , rear
Rear Center Line installation and other SS brake line info tv4184 4th Gen T4Rs 7 07-10-2023 04:33 AM
Brake line replacement question I_bRAD 3rd gen T4Rs 20 06-28-2021 08:21 PM
Brake Line Replacement Issue sport2004 4th Gen T4Rs 8 09-19-2018 09:15 PM
Brake Line Replacement guy_wy General Discussions 2 02-25-2017 06:34 PM
Brake Line Replacement ecufishbowl 4th Gen T4Rs 1 10-31-2016 06:35 PM
