Old 02-13-2024, 07:30 PM #16
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Originally Posted by Devbot View Post
Talk to a driveline builder like Tom Woods or a local shop. There's a good chance they'll do it cheaper and better. Toyota charges about the same for a 4WD rear driveshaft, but mine was over $100 cheaper, built with DOM tubing AND came with a case hardened yoke.
For what it's worth I've had two Tom Woods driveshafts. I sent the first one back because it was bent, and then had the second one rebuilt by a local shop because it was also bent.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 02-13-2024, 08:58 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This is the first I have heard of 2 bent Tom Woods Driveshafts.. Interesting. Thanks for sharing it. :-)
Old 02-14-2024, 06:01 AM #18
gh25_'s Avatar
gh25_ gh25_ is offline
Real Name: Garrett H.
gh25_ will become famous soon enough
gh25_'s Avatar
Well... I haven't heard of tom woods before but it is not looking good for him so far. lol...
I think I'll either just buy an OEM one or there is a place here local to me called Drivelines Inc. Did a little research on them, they are supposed to be a really reputable place. The do driveshafts for BMW's, 18 wheelers and their quote "everything in between" they also make custom driveshafts for people like BJ Baldwin and his trophy trucks. Rad! If they are able to give a quote over the phone possibly and it is cheaper than OEM then that seems like a good choice. Well see what happens
gh25_ is offline   Reply With QuoteReply With Quote
Old 02-14-2024, 07:02 AM #19
thezentree's Avatar
thezentree's Avatar
They're well known in the 4x4 world, and I hate knocking them because they had good customer service and the driveshafts both worked, but they both vibrated badly at highway speeds. They'd be fine for a rock crawler, but for a DD I was frustrated pretty frustrated with how banana shaped they were.
Old 02-14-2024, 01:55 PM #20
gh25_'s Avatar
gh25_'s Avatar
Just called that local shop drivelines inc and talked with the guy on the phone he said using my factory trans yoke and rear yoke they could get a whole new drive shaft prop with 3010 outside c-clip uni joints with zerks within a range of 550 at the lowest and 650 for the highest. No doubt if I go with this place it will be very high quality work but definitely not cheaper than OEM hahaha. Benefits of doing it with this company instead of OEM is that the replacement universals is easier to replace mechanically and since it's a 3010 like the guy said on the phone it is the most common universal joint used.
Old 02-14-2024, 01:58 PM #21
gh25_'s Avatar
gh25_'s Avatar
Well thanks for your input. I would've consider them an option if they didn't sell bananas. Just makes my choices less and easier though!
Old 02-14-2024, 03:23 PM #22
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
No one mentioned tires. I don't know if you are running stock or oversize. An unbalanced, out of round or worn tire is a possibility. I lost a weight on my '18 and am experiencing vibration, starting at about 65. Just waiting for the time for rotation to have it addressed.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 02-14-2024, 04:29 PM #23
gh25_'s Avatar
gh25_'s Avatar
I mentioned in the first post in this thread the list of things I have done to my truck. Among the other things I had done a rotation and rebalance of my tires less than 1k miles ago and even right after I balanced them there wasn't much of a difference. I got the tires May of last year brand new and I even rotated them early right at the second oil change on her. I work at a tire shop so I did the balancing and rotation myself lol. I don't think it is the tires. They are only LT265/75R16 general grabber at/x. Oversized compared to stock but not by much.
Old 04-08-2024, 03:21 AM #24
gh25_'s Avatar
gh25_'s Avatar
Well, unexpected improvement to the vibrations ended up being something completely un related to the drive shaft. I still feel vibrations but it's noticeably smoother now. I bought the LC engineering aluminum crankshaft pulley since I wanted a lil more oomph out of my 4runner. I guess the old rubber must've been worn out on my OEM harmonic balancer. Went on a drive as soon as I got the new piece installed and there was definitely a difference cruising highway speeds. It's not as bad anymore. Makes sense to me though. that thing weighs like 10 lbs and if the rubber isn't damping anymore that thing is prolly causing some decent vibrations. Still planning on getting a new driveshaft tho. Still annoys me with the vibrations driving freeway speeds. kinda feels like I'm driving a bucket of bolts on the freeway. Driving in my friends tundras are so smooth where as mine is all crazy lol.
bushings , feel , play , steering , vibrations
Bad Vibrations afalex1 4th Gen T4Rs 28 02-03-2020 11:53 PM
Bad Vibrations ToyNutt 3rd gen T4Rs 7 05-05-2011 09:27 AM
Vibrations manifesto 3rd gen T4Rs 6 06-23-2008 08:26 PM
Vibrations prodigy2k7 Classic T4Rs 1 01-23-2008 04:38 PM
Vibrations 03 2WD V6 Oscarz Problems & Warranty Issues 0 11-24-2003 09:06 AM
