05-24-2011, 07:25 PM
Rear OEM Landcruiser Shocks???
I've been noticing a slight rattle when i've got the window down and the road gets kinda bumpy. It finally bothered me enough to get under there and see what was loose.
Come to find out its the shocks. I'm running the rear OEM Toyota Landcruiser shocks. When I checked the top shock mount, the bolt was loose enough to turn it with my hand. I got the socket out and tried to tighten it back up but the top of the shock, the shield part, just spins with it. Got it somewhat tightened down. Seemed to go away for a few days and now its back again.
Anyone else have this happen? Any thoughts or fixes?
I don't really wanna be driving around with these things loose. Maybe that has been my vibration issue all along?
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
05-24-2011, 08:01 PM
Real Name: Isaac
Real Name: Isaac
take the nut off on the top, clean the threads and put some blue lock-tight on there and tighten it back up... let it set over night before driving it again you shouldnt have any more issues of the shock coming lose, also when you tighten the nut back down, use a large set of channel locks(adjustable pliers) and a rag over the teeth so you dont scar/chew up the paint on the shock tube and keep it from spinning as you tighten the nut down, maybe use a lock washer too.
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
05-24-2011, 10:45 PM
X2- add a lock washer and you should be good, mine haven't come lose again. One of mine "squeaks" though which i don't know why.
2000 Limited Deckplate/ISR mod Blue Wire mod, DRL delete. 12V mod, Fog Light mod. Taco/spacers, 8wraps.1"BL 285 Kumho KL71s
05-25-2011, 02:30 PM
Real Name: Rob
Real Name: Rob
x3 - try just putting another washer on top, that fixed my problem.
05-26-2011, 01:30 AM
Well they've got the big rubber bushings on each side of the mount and those seemed pretty compressed, almost squished but its still loose. I took some pics but not sure what all you can tell from them
‘14 SR5 in white
Full RCI skids
05-26-2011, 01:33 AM
Sorry for the big pics. Damn iPhone
‘14 SR5 in white
Full RCI skids
05-26-2011, 01:38 AM
Real Name: Isaac
Real Name: Isaac
those things are way too lose, that rubber grommet at the top isnt hardly squashed down at all! you should have like at least a half inch of threads on that stud showing
and you notice how on the top of that stud its been "squared" or rectangled" off...? yeah use and adjustable/crescent or fitted open ended wrench on that a ratcheting wrench(closed end) on the nut, that will keep your shock from twisting as you tighten it down.
05-26-2011, 01:46 AM
OK. I will see if I can find something. Next day off isn't until next Wednesday unfortunately
‘14 SR5 in white
Full RCI skids
