So, I've always been an Audi fan... But - when I bought a boat... well - towing became an issue. So I picked up an 05 4Runner Sport the other day.
So far loving this car... One of my 'gripes' is there is no courtesy light over the dash - only the doors... It sure is dark in there at night!
Second, I'd like to add navigation, bluetooth, backup camera, ipod cable. I always have liked retaining the 'stock' look. But is the factory navigation any good? (I'm sure it's overpriced compared to aftermarket)
07 V6 SE | Bilstein 5100/FJ Swap @ .85 | VSC Override | Alpine INE-S920HD Nav w/ Rear Camera | Map Light Mod | LED Conversion | Bluetooth Integration | Bushing Upgrade | Heated Seat Conversion | Custom Console Organizer | AutoDim Mirror with Home Control | More to Come...
You can also get a steering wheel control interface so that you can retain the functionality of the buttons on your steering wheel. I believe PAC & Metra both make their own versions of this product.
__________________ Golden State RUNNER
2008 Galactic Gray SR5 4x4 V6 Build Thread Photo Album
You can get the stock look with a double din if you buy the factory surround. I installed a Kenwood DNX model and it looks great and does what you want. It also has Garmin GPS so map updates are easy.
I did a whole thread on my install. Check my signature.
i've done the OEM route and it's fairy easy. Just make sure you get the NAV unit for cheap. If you get it from the dealers, forget it, TOTALLY not worth it. Here are some links you can browse to see what you are up against. Not difficult
There are other threads regarding some details (radio bezel/LEDcolor change/etc), but this mod is essentially plug and play provided you have a JBL amp or not. If you do, this mod is 100% doable. If not, you need to get the correct NAV H/U.
OEM: later year NAV units (depending on which model you get), do come "pre-wired" to accept an AUX input jack, but that is something else you would have to install. Going aftermarket would be tons easier.
Off the top of my head, there is product from Scosche that is a plug and play kit that integrates the ipod onto the NAV's display, pricey, but very cool. Keeps it "factory looking".
Cookie, could you tell me if all head units have backup camera capability? I am looking to replace my 04 head unit (35241) with an 03(35240). I broke the screen on mine. If the plugs totally match on the earlier h/u, would I get backup camera capability?
I think you're right. aftermarket will be way easier. I just need to make sure I find something that will retain the steering controls.
if anyone has any tips about that... let me know!
I think there are newer models out there but I put in a Kenwood unit with Garmin GPS and am still happy. I tried to document the install thoroughly. Hopefully the newer Kenwood models address the sluggish iPod controls but overall, it is a pretty good system and has all of the features you might want.
No, early models that did not come with a backup camera simply do not have the internal hardware. Replacing the screen won't do an thing.
Yikes. How hard would it be to put in a newer display? Mine has the dvd unit in cargo area. The newer ones are internal. Are there harnesses to make my wiring compatible?
Wiring harness: I don't think so. From what I understand, there is a 24pin connector in the back of the camera equipped NAVs that the non-camera NAVs do not have. You would have to get pinouts for both and make the appropriate connections. READ: Pain in the Ass
Display install: I've never done it, but it's a matter of taking out small screws and CAREFULLY unplugging a very delicate "ribbon cable" that connects the screen to the head unit. Damage this and it's all over.
If you want to keep the an OEM NAV, get a unit with an INTERNAL DVD drive (maps).
This should help you in deciding which unit to get. Again, only if you want a toyota NAV. I try to update the info when I get a hold of it. But the information is pretty accurate IMO.
