Originally Posted by Ultarnr75
To anyone that has installed their seat warmer with by tapping into the the green wire and moving the relay.
I know to remove the inline fuses since this will use the fuse under the hood, but what about the relays on the harness for the heat pads?
Do those need to be removed since this setup will be using the relay under the hood?
Thanks
I left the inline fuses (behind the HVAC panel) as they were lower amperage, and for each individual seat. But I need to remember that in case one blows.
I don't see it as being needed...
I don't recall installing any relays inside the cabin.
