Old 11-26-2005, 10:22 PM #1
TeryT's Avatar
TeryT TeryT is offline
TeryT is on a distinguished road
TeryT's Avatar
Home Link Assembly Loose
I noticed today that the piece that houses the Home Link is a little loose. This piece also has a sunglass holder & the front map lights.
Does anyone know how it's held & how to tighten it up?
Thx!
2003 V8 4x4 Sport 4Runner TRUCK OF THE MONTH SEPT. 06 - still tows a 25' ultralite Rockwood 2502 travel trailer all over creation!
MODS: GlowShift tranny temp gauge; Hayden 526 tranny cooler/fan combo; Hopkins Insight brake controller; Bilstein 5100 shocks
Hensley Arrow hitching system - quite simply the best for zero sway towing!
TeryT is offline   Reply With QuoteReply With Quote
Old 11-30-2005, 12:30 PM #2
MicaBlue03's Avatar
MicaBlue03 MicaBlue03 is offline
MicaBlue03 is on a distinguished road
MicaBlue03's Avatar
The front portion is held up by a couple of plastic shafts with metal clips. These fit into square recesses in the metal reinforcements on the underside of the roof. The rear portion is held up in two ways. One is by plastic tabs which extend past the edge of the assembly and rest on something (presumably metal) above the headliner. It is also held up by a rectangular piece of a velcro-like material which engages a similar material on the underside of the inside of the roof assembly. This stuff is probably to prevent looseness and vibration.
As far as how to tighten it up, it depends on whether the front portion or rear portion is more loose. The rear portion might be tightened up by simply pressing up firmly on it. The front portion may be loose if it has been previously removed (say for the sunroof rattle fix). It's typical for the metal clips covering the plastic shafts to get bent when the assembly is removed. If those clips aren't bent back correctly the whole thing could stay loose.
I did the homelink retrofit (just bought the part which includes the sunroof switch, lights, homelink, and sunglasses holder, and installed it) and I think there might have been pictures and instructions here on the forum somewhere. Not sure, though.
Hope this helps.
MicaBlue03 is offline   Reply With QuoteReply With Quote
Old 11-30-2005, 02:01 PM #3
AlexJet's Avatar
AlexJet AlexJet is offline
AlexJet is on a distinguished road
AlexJet's Avatar
I have the same problem. My front part is loose and I know that it's a metal clip. I'm just waiting for the regular service time to ask them to fix it.
2005 4Runner Limited V6
Safari Snorkel, Custom 5”, ARB Lockers, 4.56 Nitro Gears, 285/65-R18 + 18x9 (-12), 315/70-R17 + 17x9 (-6), ARB Front Bumper, WARN 9.5xp, Custom Full Undercarriage Protection: bumper to bumper, Custom Rock Sliders/Steps, CBI Rear Bumper.
2016 4Runner Limited
Safari Snorkel, 3" OME, 285/65-R18, 18x9 (-12), Custom Rock Sliders/Steps,... work in progress
AlexJet is offline   Reply With QuoteReply With Quote
Old 11-30-2005, 09:12 PM #4
TeryT's Avatar
TeryT's Avatar
So I'm not sure how to get to it. Mine is loose in the front - by the windshield.
My runner is now on extened warrany, and I don't think it covers minor stuff like that.
Old 12-01-2005, 02:54 AM #5
MicaBlue03's Avatar
MicaBlue03's Avatar
If it won't stay up tight when you push it up (I'm sure you've tried) the only thing I can think of is to pull it down, re-bend the clips to their original form, and push it back in.
Pulling it down (by pulling down on the front edge, nearest the windshield) took a lot of force for me (presumably that was the bending of the clips) and I'm not sure exactly how to bend them back so they'd be secure.
Maybe others can offer more detailed suggestions. Did you ever have the sunroof rattle mod done?
Old 12-01-2005, 11:02 AM #6
TeryT's Avatar
TeryT's Avatar
The sunroof mod hasn't been done to my knowledge - nothing in previous owners records on it.
I hate to pull it down if you're not sure how to get it back up right!
Old 12-01-2005, 01:28 PM #7
AlexJet's Avatar
AlexJet's Avatar
Same as mine. Front right part. I know it's a clip. Extended warranty covering it for sure (I checked mine). So I'm waiting for regular service and will ask them to do it all together.
Old 12-01-2005, 01:56 PM #8
TeryT's Avatar
TeryT's Avatar
That's great. I thought plastic parts were excluded on the Platinum.
Old 12-01-2005, 10:21 PM #9
RickyCRX RickyCRX is offline
RickyCRX is on a distinguished road
The front of it just pulls straight down... The back will 'pivot' down slightly, then once the front clips are released, it slides a little forward and you it will simply fall out. It's a piece of cake to take out and put back.
I have had mine off on a couple of occasions. Once to install the new upper console piece with the HomeLink (my 4Runner didn't come with it from the factory), and once to hardware my V1 into the wiring harness for the sunroof overhead. My clips got bent on both occasions and would no longer hold the piece firmly to the roof, nor would they clamp tightly on the plastic tabs they slide into on the console module itself.
A few minutes of carefully bending them so that they function properly is all it took. Mine stays up there quite firmly now.
The next time I plan to remove it, I'm going to probably just buy two new clips from the dealer before I pull it down. That way I don't have to mess with it. I can't imagine those clips costing more than a buck or two.
Ricky
2003 2WD Galactic Grey V8 Sport
RickyCRX is offline   Reply With QuoteReply With Quote
Old 12-01-2005, 11:00 PM #10
AlexJet's Avatar
AlexJet's Avatar
Those clips are metal ones.
RickyCRX, before buying them, pass the service department and ask for assistance, saying that this part came loose and you need just those metal clips, it's a piece of cake job and you're going to do it yourself instead of leaving the vehicle for an hour or more. They usually going to service box, grab a couple of those clips (man you can't imagine, how many different clips and small replacement parts they have in those boxes and quantity of them) and give you for FREE (nobody even count them).
Old 12-01-2005, 11:29 PM #11
TeryT's Avatar
TeryT's Avatar
Ricky
Thanks! Just for understanding - which do you consider the front? The side by the windsheild?
Old 12-01-2005, 11:39 PM #12
AlexJet's Avatar
AlexJet's Avatar
Yes. Windshield side is front, sunroof - rear
Old 12-02-2005, 12:14 AM #13
That might work if the vehicle is newer, but my 4Runner has over 63k miles on it... Way outside a warranty period, so I don't know if they'd be as willing to do anything.
Old 12-02-2005, 12:15 AM #14
Yep!
Old 12-02-2005, 12:19 AM #15
AlexJet's Avatar
AlexJet's Avatar
Do not tell them so. Just pass by and ask them. That what I'm usually doing. I'm coming there, explaining what I want from them. They usually trying to fill up the paperwork and try to get my keys to see the mileage, but I'm stopping them with the note: I can do it myself, just give me the parts, you'll take too much time for the same job. They usually go for it. Another thing: you have
Transmission Leak - Dip Stick Assembly smallbrian 4th Gen T4Rs 5 01-07-2009 09:12 AM
Headlamp assembly for '06 4Runner jmc5500 Maintenance/Detailing 2 03-04-2008 09:57 PM
Headlamp assembly for '06 4Runner jmc5500 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-04-2008 01:30 PM
Finally joined the iPod generation, Ice Link or Dice? snowjay Engines / Suspension / Wheels / Tires / Audio / Accessories 21 09-03-2006 03:33 PM
Home link Console Forsale toyo Classifieds - buy & sell (no commercial ads please) 3 05-10-2005 05:52 PM
