Old 04-11-2024, 09:20 PM #1
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Does anyone know if a V6 4x4 frame will work on a V8 4x4?
Basically just what the rifle says. I know thet are 2 different part numbers and the trans crossmember is different. I've searched all over a can't get a definitive answer. Some say it will work, some say no. Some say there are some accessories that bolt up differently.
Any help would be appreciated.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 04-12-2024, 08:12 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
It will work but there may be a few mods necessary to "make" it work, but no hill for a climber.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 04-12-2024, 10:05 AM #3
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
The motor mounts will most likely be different. That could be a welding/fabrication endeavor.
As you mentioned the difference in transmission cross members, hopefully the frame would have provisions for either one to be mounted.
After that?
Different drive shaft length? possibly...
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 04-12-2024, 08:24 PM #4
inscarguy's Avatar
Real Name: brian
inscarguy's Avatar
Real Name: brian
After that?
That's my worry, the engine mount area. If they bolt up differently I don't want to start welding and either get it wrong or create another problem.
Old 04-19-2024, 09:19 AM #5
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
CUrious how this ended, were you able to confirm what or if there is any significant difference?
@BlackWorksInc may know
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 04-19-2024, 03:55 PM #6
inscarguy's Avatar
Real Name: brian
inscarguy's Avatar
Real Name: brian
I haven't yet. I was hoping more would chime in with so many views. I'm in the middle of doing a timing belt and pulleys, water pump, intake gasket, all fuel injectors, VCG, new hoses, detailing the engine with everything apart so i kinda put the other 4runner on the back burner.
4x4 , accessories , answer , definitive , work
Frame Flusher for Cleaning Inside Boxed Frame - Anyone Have Experience? Bluesky 07 General Discussions 5 08-29-2023 04:23 PM
In the middle of the frame swap: what’s the Part Number for the fuel/brake line to frame retaining clips? cl4Rk 3rd gen T4Rs 12 04-23-2021 03:43 PM
Need Advice: Frame Damage From Accident and Frame Rust Whammy 4th Gen T4Rs 11 08-29-2018 07:46 PM
Rusty Frame from IL now in the desert. Still spray the frame? New Frame? Rancho5 3rd gen T4Rs 9 03-02-2018 04:40 AM
Frame Restoration on my 97 (frame removal, repair, and upgrades) blain_gatterdam 3rd gen T4Rs 2 05-21-2015 12:17 PM
