Old 01-16-2014, 05:33 PM #1
Garage Built Rides Garage Built Rides is offline
Garage Built Rides is on a distinguished road
5th gen to 4th gen suspension swap?
Hi all, I have a 2007 SR5. It has about 150K on it, and both front struts are leaking, and of course braking and turns have gotten a bit dodgy. I looked at buying some new struts and rear shocks at the local parts store. Then I found a complete 2013 5th gen trail suspension (struts, springs and shocks) with 7500 miles on them for $200!! I have seen lots of info on the FJ to 4th gen swap, but not the 5th gen to 4th gen swap. Is it a straight bolt in? can I expect a little lift? stiffer ride? etc etc. Thanks in advance for any help.
Garage Built Rides is offline   Reply With QuoteReply With Quote
Old 01-16-2014, 08:18 PM #2
wnelax04sr5's Avatar
wnelax04sr5 wnelax04sr5 is offline
Real Name: Ethan
wnelax04sr5 is on a distinguished road
Real Name: Ethan
it is NOT a straight bolt it. the lower shock mount bushing is incompatible with the LCA mount. rear shocks aren't totally comparable either, the hole for the top shock mount isn't big enough and would need to be bored out, IIRC. i had inquired about putting a 5th gen OME kit on my 4th gen and found that it would not work out with modification.
A lot of stuff I didn't need...
My Build
Originally Posted by kfitz77555 View Post
oh my god the erection I have from this thread is unreal.
wnelax04sr5 is offline   Reply With QuoteReply With Quote
Old 01-16-2014, 08:43 PM #3
JB.'s Avatar
JB. JB. is offline
JB. will become famous soon enough
JB. JB. is offline
JB.'s Avatar
Garage Built Rides,
The springs should work, though, and should lift the front about like FJ springs would. Slightly less in the back.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
JB. is offline   Reply With QuoteReply With Quote
Old 01-17-2014, 11:15 AM #4
hmmm. This was the only thread that I could find on here about this swap, 5th gen suspension In it a member mentions that he sold his 5th gen suspension to another member with a 4th gen and he says it "bolted right up" Maybe I'll try to shoot him a PM
Old 01-17-2014, 06:57 PM #5
Silvr Bullet Silvr Bullet is offline
Silvr Bullet is on a distinguished road
I just recently did a 2012 FJ suspension swap on my 2006 T4R. The 2012 FJ and the 5th gen suspension are the same. But as stated above the suspension needed to be modified. The lower bushing on the front struts needed to be grinded down (I used a table belt sander), it wasn't a whole lot but a sanding block isn't going to cut it. The belt sander works really well because it sands both sides evenly. Now the back shocks also won't fit and the hole in the frame of your truck will need to be widened. You will need to get a high speed steel step drill bit, you can get them at harbor freight in a 2pack, the bit you need is an eleven step bit it goes from 1/4"-1 3/8". Do not purchase this from any home improvement store they charge $50-$60 for 1 bit, harbour freights are $11 for 2. This swap takes time and patience, but is possible. The downside is that you are altering the rear holes in your frame and will always need to get parts for a 5th gen when it comes to your rear shocks. On the front you are only altering the strut not the frame, so you can always replace with 4th gen parts. It is a lot to take on so prepare yourself or look for a suspension that bolt up directly for the 4th gen. If you decide to do the swap, let me know and i can help with any question.
Silvr Bullet is offline   Reply With QuoteReply With Quote
Old 01-20-2014, 11:00 AM #6
Thanks sooo much for that reply. It was exactly what I was looking for! I actually ended up buying an FJ suspension with less than 10k miles on it. He bought the suspension for his 4th gen but then sold his 4th gen and had the parts laying around forever. He "thinks" they are from a 2010, we'll see. I picked it all up for $100 he even threw in some extra 4th gen headlights and a complete 4th gen XREAS suspension ?? I guess I'll sell that. I'm sure I'll be bugging you with a couple questions. Thanks again
Old 01-24-2014, 10:21 AM #7
Not a problem, sounds like you got a great deal! Just pm me if you need anything or need to talk it over before you start.
Old 01-24-2014, 11:05 AM #8
JDMcQ JDMcQ is offline
JDMcQ is on a distinguished road
I did the 5th gen Trail edition swap on my 2006 4Runner. The install was just like that for the FJ swap.
I found the shocks to be way too soft for my truck. It bobbed up and down and nose -dived heavily under braking. By comparison, the 2013 FJ Trail Teams suspension I have now is much firmer and more controlled.
JDMcQ is offline   Reply With QuoteReply With Quote
Old 01-24-2014, 12:30 PM #9
Thanks again for the info guys! I'll keep you posted on how the install goes, maybe even post some pics
Old 01-25-2014, 12:12 AM #10
Code2 Code2 is offline
Code2 is on a distinguished road
OMG i would even think of using the 5th gen suspension its lacking BIG for a better word. so loose and flopping is scary
I have a 5th gen and took it to tenn. and OMG the curving roads were beating the hell out of that thing. to soft in turns cause to much side to side action. so soft couldnt feel the road. had to put thru like a old fart since i didnt feel like rolling the truck and the brakes on it lets not even go there they are junk
Took the 08 down there and it was like it was on rails. handles the curve like a dream and way above the speed limit and the braking so much better and efficient
Code2 is offline   Reply With QuoteReply With Quote
Old 03-03-2014, 03:53 PM #11
Done
Hey guys the swap is done and it came out great. The donor suspension ended up being a 2011 FJ with about 8k miles. The mods to the struts and rear shock mounts were not bad at all. With the brake job, I was in 8hrs. I used the no spring compressor method to remove the front struts, WAY easier and safer than stupid spring compressors. The rig feels much stiffer and more in control than before. Gained about an inch up front and about a half inch out back. Maybe I'll level it out with some spacers down the road. Thanks for the input and help everybody! I'll post a couple pics as soon as I figure out how.
Old 02-09-2016, 02:45 PM #12
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Does anyone know the spring rates for the 5th gen? They look bigger than a 4th gen, so I assume they have higher spring rates.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 05-01-2016, 11:49 AM #13
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
rear coil lift?
same as the FJ or less/more? TIA
jrm is offline   Reply With QuoteReply With Quote
Old 04-24-2018, 03:42 PM #14
AJD0331 AJD0331 is offline
AJD0331 is on a distinguished road
5th gen on 4th gen questions
Hey guys I'm new to this forum even though I've been using it for a long time for information on my vehicle this is the first time I've ever posted. I see it's been awhile since this thread was last going so hopefully someone with more knowledge than me still looks at it once and a while. I received a full suspension off of my friends 2015 4runner ( front and rear shocks w/ coils/springs and upper control arms off vehicle w 5k miles). I've already done new upper and lower control arms and ball joints and I'm about to remove the xreas and install the new shocks. Ive researched that I have to widen the hole for the upper bolt on the rear shocks. Does anyone know to what size exactly it needs widened and what size bolt it will need? Also is the Lowe bolt for rear shocks the same from 4th to 5th gen? And last question, I'm picking up a rough country level kit for it and I feel like I should know the answer but I'm confused. Would need the 4th gen kit or the 5th gen kit? Thank you in advance for any help or if someone could direct me to a more recent thread.
2003 4runner sport v8 full time 4wd, xreas w/ leveling spacers. Almost 300k and just about all original(just now starting to replace/build things).
AJD0331 is offline   Reply With QuoteReply With Quote
Old 04-24-2018, 04:21 PM #15
Elan750's Avatar
Elan750 Elan750 is offline
Elan750 will become famous soon enough
Elan750's Avatar
I have rear 5th gens and DID NOT have to widen the frame holes. I did modify the bushings. I cant tell you specifics but I cut one in half. Once you get the old one off, and you have the new ones, you can figure it out. you just need a rubber sandwich with the right washers.
2005 4Runner Sport 4wd v6 -totaled!
2003 Lexus GX470
Elan750 is offline   Reply With QuoteReply With Quote
FJ TRD Suspension Swap WhiteLightning 4th Gen T4Rs 11 08-30-2012 05:24 PM
Another suspension swap brewing... toyotatech84 4th Gen T4Rs 5 02-05-2012 09:01 PM
4th gen LR Suspension Sag After FJ Swap SMEE 4th Gen T4Rs 7 08-08-2011 08:34 AM
FJ suspension swap SCRunner6 4th Gen T4Rs 8 05-03-2010 08:37 AM
Suspension swap, need help jetboy1975 4th Gen T4Rs 7 05-02-2010 09:11 PM
