Any V6 guys running OME 885's with top plate spacer? with no armor
zeronine
I have OME 885's on the way with superflexes going in the rear. Any of you V6 guys add the top spacer? I'm looking for a level stance rather than a rake. Will the top spacer make it higher than the rear without armor/weight in the frony? Will 885's alone be level? Lemme know what y'all think!
Thanks!
No personal experience with the v6, but I got 3" with the 885's and a v8. I'd expect 3.5"+ with the v6, you should not need the top plate spacer to level it out.
BUMP!
V6 - 2009 - SR5
I also have 885's and 5100s for the front ready to install once I get my UCAs. Not too worried about getting extra lift from a spacer but wondering how many of you added the driver side spacer to correct lean.
For those of you that didn't add a spacer, do you wish you had? is it that noticeable?
BUMP!
V6 - 2009 - SR5
Add rear spacer to correct the lean, 5100's are already at about the longest total shock length you would want to prevent CV binding. I was able to get away with a very thin top plate spacer on the driver side on mine when I had that setup but it didn't fix the lean completely.
Interesting. I'd be going with a 0 on the 5100s.
How noticeable is the lean? I don't think I'd be someone who would be super picky about it but I figured I'd address the issue as i'm swapping out the suspension.
Yes don't ever go above 0 with 885's (or any 2-3" lift springs for that matter) on 5100s. Plenty of softroaders blew them up that way and got no warranty. I only noticed the lean because I'm particular and measured, and measured, and measured. If I never read the forums I'd probably never know! haha
