Question on FJ Struts on 04 4Runner
frostyflammable
First, I have extensively read the sticky on the swap (https://www.toyota-4runner.org/4th-gen-t4rs/78803-compiled-fj-springs-lift-info-4th-gen.html) and the results from those that have done the swap (https://www.toyota-4runner.org/4th-gen-t4rs/78933-4th-gen-all-whove-done-fj-swap.html) to get familiar with this process.
All the information so far I have read has been excellent, the sticky basically answered all of my questions. I am in somewhat of a unique situation that I have no seen discussed yet, and hoping someone has done something similar so I can see if I need to purchase spacers.
On my 04 4Runner SR5 V6 2WD I will be putting on the OEM FJ Cruiser shock and spring (from a 08 FJ Cruiser 4x4) but leaving the rear springs alone. From the sticky, it was recommended to add a 1/4in spacer (You are being redirected...) to level the truck, however since I am leaving the rear springs alone and only replacing the front struts with the FJ struts, would I need the spacer as well? I like level or a little bit of rake, just afraid if I am not changing the rear springs that the 1/4 spacer will make it look like it has a somewhat of a Carolina Squat.
Anyone have any pics of a V6 2WD with this setup they can share?
Thanks!
I have a V6 and did the 08' FJ suspension with the coil all around on my 08' SE. I did a straight swap front and rear without spacer. I was able to get closer to level but not completely level. I would say since you're not replacing the rear and the rear is the original springs, you might skip the spacer in the front. Just an opinion and a guess. Good luck!
seltzernator
