Can I add top plate spacers to my OME lift?
ThatRed4thGen
I'm thinking about buying some trim packers for my 4th Gen. Right now my setup is:
Front Suspension
OME90000 Shock
OME2886 Spring
OME95PF5 Lean Spacer
Rear Suspension
OME60004 Shock
OME2895 Spring
My plan would be to add two Top Plate Spacers (1/4") to the front, one on each side and two OME Rear Trim Packers 10MM to the rear, one on each side. My goal is to gain just a little more lift over the OME lift for a little better approach angle and for looks.
https://i.imgur.com/zqciCcd.jpg
I also run the toytec top plate spacer with my 886 ome springs. I dont think its recommended with these springs, probably because it increases the cv angles. I've had no noticeable issues.
Jhunt
