Demello LED turn signal and hyperflash- Has anyone solved this issue with a resistor?
PAULUNM
On the verge of buying a Demello bumper with the LED turn signals- but I think the hyperflash turn signal will drive me crazy. Has anyone successfully addressed the hyperflash with a resistor? If so, which resistor worked?
I also wonder if the LED could be replaced with a traditional bulb unit....
usually for OEM led bulb replacements, an in line resistor will fix the hyperflashing, it should be the same
SuperBrightLEDs.com has what you're looking for:
RL-650 Tail Light Load Resistor kit $4.95
These are what I used on my LED front signal conversion...worth it.
Perfect- thank you. I assume you only needed 1 per side?
if you dont have drl, i suggest you to replace the flasher relay, then you can run leds on all turn signals.
I don't have DRL- but my searches yielded a number of posts with people having to modify their flasher relay- rather than just replace.
Do you have a part number of a flasher relay that you've used?
