Mod Teaser...
morphious
Going to install these tomorrow and see how they work. Any guesses what this mod might be?
IMAG0403.jpg~original
Finally got around to getting them hooked up. Went with orange/yellow leds to match the rest of my interior lights. Here's a couple of low quality quick pics to show them in action and give you an overall look.
IMAG0408.jpg~original
IMAG0410.jpg~original
[MENTION=101314]sr3tlaw[/MENTION] Thanks! I went with a simple PAC 80amp as I was able to pick it up at a good deal in my local electronics supply store and I really don't plan on needing to jump the truck from my aux battery through the isolator. Easy enough to upgrade to a higher amp isolator in the future ever arises, but I doubt I ever will.
Thoughts!
[MENTION=93193]morphious[/MENTION]
Curious, have you ever ran the deep cycle very low - as its intended, and notice any hiccups in your charging system with the stock alternator.
Here is an interesting bit of info. Because I was being ballsy and wanted to try things out, I left my headlights on for about 3 hours while I was playing baseball to see if the alternator could recharge my red top starting battery. Since my two batteries are isolated when ignition is off it only drained the Red Top. When I went to start the car it started fine but after getting to my destination the alternator started screaming. Long story short - my alternator went bad and I had to replace it (replaced with OEM).
Found this was odd because in the case of me draining the Yellow Top (deep cycle) aux battery, I ponder if the alternator do the same thing and fail to recharge.
If it is 80 amp continuous, it probably has a much higher peak rating, and would be ok to jump start with on the rare occasion.
Prior to changing to a 150 Amp breaker, I had a 70 amp breaker at the Aux battery end (150 amp already at the main battery) of two batteries, and it jumped a few times without issue. The more important factor will be wire size. Keep it 2 gauge or larger. :)
[MENTION=101314]sr3tlaw[/MENTION] [MENTION=67786]4RunAmok[/MENTION] B smart, I have ran down a dual battery system with NO isolator and killed it, no start; and it (the 4runner) charged everything fine. Yes, it will MAX higher (i believe double, 160amp), but I don't think any of us need any more amp than the stock alternator puts out. I only ran 6gauge from battery to battery. Is there a place I need to run bigger gauge wire than what comes stock on my truck?
Then I honestly must have had a faulty alternator.
6-AWG will do alright but nothing smaller. With DC current, bigger is better - most folks feel much more comfortable at 2-AWG for any current-intensive applications.
If it makes you feel any better; currently I have 6 AWG to-and-from my dual battery system. I do have intentions of moving up to 2-AWG for voltage increases.
