Old 06-22-2015, 05:39 PM #1
FL054runner FL054runner is offline
FL054runner is on a distinguished road
Rear OEM TOYOTA 4 RUNNER DIFFERENTIAL 3.73 (3.727) missing teeth!
Ever since my rear went out in my 05, I have been looking for a lower-cost replacement that I would not have to deal with the dealer for.
The ring gear lost 4 teeth so it just won't go for long without getting stuck on the stripped part of the gear.
I removed the differential "chunk" and took the ring gear out, thinking that was all I had to do. However people tell me I should replace the ring and pinion gear, oh then I also better get a crush sleeve, pinion seal, two new bearings all ordered through the dealer... so much for doing it myself. Already over $300 spent and now the guys at the shop are telling me the pinion gear is too short!??!!?
I was told that I have a: " OEM TOYOTA 4 RUNNER REAR AXLE DIFFERENTIAL E-LOCKER 3.73 (3.727)"
Anybody know where I can just order the whole assembly or what other ones might fit my 05 without causing any other problems??
If anyone can help me please and thank you!
FL054runner is offline   Reply With QuoteReply With Quote
Old 06-22-2015, 06:01 PM #2
fdbyrne fdbyrne is offline
fdbyrne is on a distinguished road
Just get a drop-in 3rd member from ECGS.
2004 SR5 4x4 V6 - With New Head Gaskets
fdbyrne is offline   Reply With QuoteReply With Quote
Old 06-22-2015, 10:22 PM #3
t-man t-man is offline
Real Name: Tony
t-man is on a distinguished road
Real Name: Tony
^^^ what he said. I tried and tried to find a cheaper source and I couldn't even find a mechanic that could do it for less than $1100 and that was without a warranty. 5 year warranty from ECGS and they use a solid spacer so it won't deflect and break again, at least not without some SERIOUS abuse!!!!
$600
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
t-man is offline   Reply With QuoteReply With Quote
Old 06-22-2015, 10:24 PM #4
RPS13 RPS13 is offline
RPS13 is on a distinguished road
I rebuilt one myself, and consider myself pretty good at wrenching. With a press and air tools, it took me a solid 7-8 hrs to do it myself. That's with a secondary diff to build up on the side.
I wish you had posted this earlier, I threw the other one with a dead pinion bearing and crush sleeve away last week. Was taking up space in the garage and had to clean out...
'92 Nissan 240SX - 400 HP/2500 lbs
'07 4Runner Sport Edition V6 RWD
RPS13 is offline   Reply With QuoteReply With Quote
Old 06-22-2015, 10:26 PM #5
...and getting to the point... the ECGS deal is pretty good after experiencing how much of a PITA it is to do your first time. 90% of it was setting the pinion shim height, but I'd strong recommend a solid spacer. No way in the world I'd do another crush sleeve after having to do all that as a result of it...
Old 06-23-2015, 02:25 PM #6
Staceman's Avatar
Staceman Staceman is offline
Staceman is on a distinguished road
Staceman's Avatar
Here's a few junkyards that have them used. Give them a call to see what they would charge to ship..
2006
Carrier
Lexus GX470 [P] AA1447 $500.29 All Auto Parts Co. -- Gold Seal USA-CA(Fontana) Request_Quote 1-800-797-4595 Request_Insurance_Quote
2005
Carrier
Toyota 4Runner AT,4x4 06603 $500 Dallas Auto Recycling USA-TX(Dallas) E-mail 972-286-4707 / 972-642-2222
2006
Carrier
Toyota 4Runner 4.7,AUTO,4X4,107K REAR AXLE; (3.73 RATIO), 4X4 A $VX945 $385.01 LKQ - Smart Parts USA-WI(Hustisford) E-mail 1-800-349-5850
2006
Carrier
Toyota 4Runner 4X4 REAR CARRIER 3.73 RATIO 234958 $375 Scott's Auto Recyclers USA-CO(Ft.-Collins) Request_Quote 800-767-8640 / 970-498-0662 Request_Insurance_Quote
Staceman is offline   Reply With QuoteReply With Quote
Old 06-23-2015, 02:44 PM #7
Jeremy556's Avatar
Jeremy556's Avatar
+1 on the ECGS. You do not have an e-locker, if stock.
Old 06-23-2015, 02:49 PM #8
CO_SR5 CO_SR5 is offline
CO_SR5 is on a distinguished road
I also recommend ECGS, I just replaced my rear third member and changed gear ratio. I am now waiting on the front. A local shop where i used to live wanted $2800 to rebuild the rear and $2000 used, that was just for the rear.
I got both at ECGS for around $1300. The 5 year warranty is also a plus, that should get me another 100,000.
CO_SR5 is offline   Reply With QuoteReply With Quote
Center differential + rear differential + front differential = confusion! badburro 5th gen T4Rs 37 01-29-2019 12:40 PM
Quick advice, pls: 1997 Toyota 4Runner, 4wd, locking rear differential Tom P. 3rd gen T4Rs 6 04-12-2012 07:41 PM
Oil Leak in rear wheel Toyota 4 Runner reymond General Discussions 10 02-03-2012 10:38 AM
WTB Rear tailgate 1989 toyota 4 runner mossy Classifieds - buy & sell (no commercial ads please) 3 08-14-2006 07:11 PM
