05-24-2020, 08:18 PM
#901
Been working on my brother's FJ this weekend helping install Dirt King heimed long travel, Marlin LCA gussets, spindle gussets, new bearings, RCV axles, and the cam tab delete kit.
He's pulling 12.5" of travel with his 37's, limited by the RCV axle shaft angle on full droop.
Like I mentioned I'm pulling 10" of travel with the shorter +2" Kit.
05-28-2020, 09:45 PM
#902
05-28-2020, 10:47 PM
#903
LOL a little nicer than my old setup?
05-30-2020, 09:39 PM
#904
06-02-2020, 11:18 AM
#905
Originally Posted by Inv4drZm
However, broke my new drawer slider, I think. This piece and a bunch of ball bearings fell out when sliding back in my drawer.
McMaster is sending me a new set of drawer slides to replace the broken piece, so that's nice. Love the drawers so far, can fit a bunch in them.
Had to order longer metric socket cap screw bolts for my 3/4" bumpstop spacers so once those are in we can go wheeling with my new tires and start to iron things out.
Only 30 more days until we leave for Moab/Rubicon...
Still need to build a cargo platform, relocate my air compressor and tank, figure out a cover for my subwoofer, mount my refrigerator, and a bunch of other smaller things. This year I'm not in too bad of shape. I hope.
06-02-2020, 11:44 AM
#906
So in the end which kit ends up being better the +3.5 or +2? living in Utah it’s a lot of rocks and some desert so tighter kit may be better but as you said you can squeeze a little more with wheel offset
06-02-2020, 12:26 PM
#907
Comparing the Total Chaos standard kits, I would steer clear from what I have (+2) unless you where solely wheeling in the desert, and if you were, the +3.5 standard kit is probably better in every way. With the standard kit you loose at least 2" of ground clearance at the end of the arm compared to their race series with their integrated lower uniball. Not to mention weight savings, picking up the Dirt King LCA its light as a feather compared to mine.
So now comparing +2 to +3.5 I would lean towards the +3.5. There are tight trails in Kansas too, but I doubt there will be something I can do with a +2 that I can't with a +3.5, and the +3.5 gives an inch or two more downtravel. The only reason I see going with the +2 is if you also went with the right wheels you could tuck it into the stock fender just barely, or ease of install, my kit I installed easily by myself in my driveway wheras my brother's +3.5 had enough downtravel with the shock installed you had to compress it to connect the UCA to the spindle, etc. Just a little trickier.
If I were shopping for another kit, I would be looking at Dirt King or +3.5 Total Chaos Race/Expedition kits. Or JD Fabrication +2.25" when they get produced. I might eventually swap to the JD kit.
06-02-2020, 12:42 PM
#908
06-02-2020, 12:47 PM
#909
Originally Posted by SumoRerun
Yes I just bought the JL one. I've seen where people cut the plastic panel and add a grill to it which I will attempt. If it doesn't work for some reason I can make an entire new panel out of aluminum and rivnut it on. Another option I think is to find an OEM subwoofer panel but that can get pricey.
06-02-2020, 03:38 PM
#910
Real Name: Aaron
Real Name: Aaron
Pretty off-topic, but what CB antenna mount are you using? And 3' length? I'm having trouble figuring out where to put mine.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
06-02-2020, 03:52 PM
#911
Its a Diamond K400 mount w/ 2ft Firestik.
It's worked well and I would recommend it though I don't use it much. I'll be looking into mounting it on my bumper with a longer antenna and a quick disconnect, or at least routing the CB cable through the hatch better. Its kinda hard to route from that location and has been dangling from the door jamb for years now. Minimum effort, you can see it in the cargo drawer pics above.
06-02-2020, 04:35 PM
#912
Good info to know I will be keeping this in mind because your truck is like a goal for my 4th gen lol funny how your old ucas are on it. I also am wanting to see the marlin kit but have been seeing the realization I probably will have to go with a normal long travel kit just for ease of getting one.
06-04-2020, 11:25 AM
#913
Real Name: Aaron
Real Name: Aaron
I've heard a lot of good things about the Diamond mounts but I'm considering going the same route. Bumper mount w/ a 5' Firestik. Strictly for routing the cable, would be completely sealed without running through any jambs.
At that point though I'm sure the hatch will hit it when opening, so a QD may be the way to go. Probably overthinking it in all reality haha.
06-06-2020, 07:25 PM
#914
Its 100 degrees outside but the mods must continue.
The gameplan:
Partway through:
06-06-2020, 08:12 PM
#915
Real Name: Brett
Real Name: Brett
Between the suspension work, the metal fab/welding/exhaust work, and the woodworking, you should just open up a custom mod shop my friend.
I wish I lived in your area just so I could come over to help out and learn some stuff lol. I'm 57 yrs old, but I've always said I can learn from a 4 year old or an 80 year old. Always look forward to your posts. Keep em coming.
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
